Go Back   The RadioReference.com Forums > Commercial and Professional Radio > ICOM Land Mobile Radio
ICOM Land Mobile Radio Discussion forum for ICOM land mobile radio equipment such as the IC-F series radios. Please do not post amateur radio topics here.
Old 10-29-2011, 4:22 PM
Default Cannot connect my F5021 for programming
I'm using windows xp. Software version 3.2. Using the USB version cable. I went through the ports and all but one does not work. It keeps asking for a driver which I don't have. So I found port 3 to work however I get this issue...
"No answer from transeiver. Check the following; comport settings, cloning cable connection and transeiver power is on".
I don't know what else to do.
Amateur = KB3MJZ was KB3YRT
GMRS = WQOJ291
Kenwood TS-8505, Wouxun KGUV6D, Motoroa 356R, Icom 5021, Icom 6021, Uniden Solara DSC
Old 10-30-2011, 8:04 PM
Default Driver
What part # is on the cable? I could email you the driver so you could install it. Send me your email and # on the cable.
Dave
Tekk Comm
Old 10-31-2011, 11:22 AM
RPC-M-U OR RPC-IM-U. Can't read very well
GMRS = WQOJ291
Old 03-20-2012, 11:25 PM
Dave
Tekk Comm
I got the same program with my new IC-6021 just purchased. My computer set up can program my IC-6023 (Australia version of the IC-6021). But the same setup cannot program the IC-6021. Would you be able to help? The computer can communicate with the USB cable but not my IC-6021, it said "illegal information- check power on, cloning cable, radio version etc".
Thank you in advance
Old 12-30-2012, 7:31 PM
In windows, try changing your baud rate (bits per second) from 9600 to 1200. This is the baud rate to which most radio's transfer data at. Goto... Control Panel > Device Manager > Ports (COM & LPT) > select/verify which comm port the device is connected too > right click on that device and select Properties > Port Settings > change bps from default 9600 to 1200 > Click OK and exit out. Now launch the programming software, power on the radio, etc according to instructions. Hope this helps!
Old 01-08-2013, 6:51 AM
Hello
You can turn on radio with key P0.
BR
Stefan
