19sargeusmc56
- Joined
- May 11, 2012
- Messages
- 50
I'm trying to test the vibrator function of this radio I just aquired.
In the CS, on the menu under COMMON....KEY & DISPLAY, there is a setting there for OPENING VIBRATION, and the help file tells me that if set to ON, the radio will vibrate for the duration of the display of the text in the OPENING TEXT field. Well, this one isn't vibrating when I turn it on. I've been thru the CS, and I don't see anything else that would flat disable the vibrator from working.....unless I missed it of course.
Any programming gooroos out there can lend a hand?
Semper Fi.
Semper Fi.
