Programming Help IC F221-1
druhe
Southwest Pa
I've been given several IC F221-1 UHF mobiles. I have a copy of CS-F100S
software and both a OPC-1122 & OPC-1122U programming cables. I am unable to get
the the laptop to connect to the radio. I have tried changing com ports, speed,
cables and gone from an XP machine to a 98 machine. All with the same results.
According to the software docs you just turn the radio on, is there a
programming mode to put the radio into. If so how ?
Any help appreciated
12dbsinad
Your software is the "S" version, it will only program the 121S/221S 4 channel radios. You need the CS-F100 software to program the 128 channel F221.
kayn1n32008
ØÆSØ
Sector 001
PM sent
sjdowlen
Lubbock, Texas
Re-check which com port your USB to Serial adapter is using. Depending on which USB port I plug my adapter into changes the com port. It could be the standard first four, or in my case com port 6. Check your laptop's control panel/device/USB adapter properties to find what com port is in use by the device.
