Go Back   The RadioReference.com Forums > Commercial and Professional Radio > ICOM Land Mobile Radio
ICOM Land Mobile Radio Discussion forum for ICOM land mobile radio equipment such as the IC-F series radios. Please do not post amateur radio topics here.
Old 06-08-2012, 3:28 PM
Default Rookie Needs Help
So, here is the situation. I am new to amateur and commercial radios and their respective programming applications. I just purchased an iCom F-6021 UHF radio, and the programming software as well as a USB cable that plugs into the microphone port on the radio to interface it with the PC. So, after installing the programming software on my Windows 7 laptop, I plugged in the USB cable to the radio, then powered up the radio, and opened the software on my laptop. Windows did it's thing with trying to find a driver for the new device, and it failed to do so, but I didn't think that it mattered anyways. when I tried to read the radio (it is factory fresh out of the box, this is my first time powering it up), I get an error message saying that there is no response from the transceiver, and it tells me to check my COM port settings, make sure the transceiver is powered on, and check the physical connections on either end of the USB cable. I know the transceiver's power is OK, and the cable connection is just fine. However, when I looked in device manager on my laptop, to try and find out what the settings were like for the COM ports, all I found was the new USB device listed, which I could do nothing with besides trying to download a driver that doesn't even work. So, I'm stuck here, and if anyone could help out, link me to some instructions, or just drop a few words of advice, PLEASE do so, it would be much appreciated. Thanks in advance!
Old 06-09-2012, 5:56 PM
So where did you get the cable and program? The cable has to use a driver for it to work.
If you have a usb cable from the internet, most of them work with a prolific pl2303 driver and should have come with it and must use com port 1 thru 4.
Old 06-09-2012, 6:26 PM
lep's Avatar
lep lep is offline
I am using a different radio but my USB port is no. 16. It worked fine until WIN update several weeks ago installed an "updated prolific driver" designed to defeat counterfeit chips from China. Using sys restore i was able to undo the new driver and go back to my original and now it works once again but still on port 16.
Old 06-09-2012, 8:10 PM
I bought the software and cable combo from The Antenna Farm :: , Your Two Way Radio Source!
I will search for that driver, and it should work on COM port 3, like I had it.
Thanks alot!
Old 06-09-2012, 8:12 PM
I got it to work partially on port 3, so it looks like I just need a driver, and then I should be able to read the radio. Hopefully the driver that I download will work fine.
Thanks for the input.
Old 09-21-2012, 10:01 AM
I am having the same problem as FHOP except that I have a 3161DT.. The driver is up to date but still no communication with the radio even though everything seems to be properly installed. My software was also purchased from The Antenna Farm. Driver version is 3.3.2.105
When trying to communicate using com port 3 it is delayed a couple of seconds before asking me to check the com port settings, cable connections and transceiver power is on. Any other port that is selected immediately responds with the same message.
Old 09-21-2012, 11:30 AM
setxrailfan The Icom F3161DT is a Digital Trunking capible radio and use's a differant program then the normal 3161.
Make sure you have the correct program software for that radio.
If you are having trouble with the USB driver, send me you e-mail address (cabletech03@hotmail.com) and I will send you proflic driver that I have never had any problem with.
Old 09-27-2012, 5:58 PM
RADIOGUY2002's Avatar
Send a message via AIM to RADIOGUY2002
Default lol
Um no it does not, maybe firmware but not software. You have to fix the com ports and make sure the driver i recognized by the PC. Also, you should really look into who your buying your equipment from. I realized their cheaper, but I see these posting all the time about software and most of them are originating from antenna farm. Perhaps, they should put out a disclaimer on how to use the software.
Thanks, Ryan. Seller of Icom Radios and Others Inquire with in.
Icom F5061/F6061-5, F43/33-4, F3161-1/4161DT-2, FR3000-1, VERTEX VXR-7000D(U)
Uniden=BC-396T & 996T, Hello IDAS
Old 09-27-2012, 6:37 PM
radioguy--you are correct--me bad, the regular 3161 and the dt version both use the same software,
I was looking at the railroad version of the raadio and DOES use a differant program.
Old 10-03-2012, 8:21 PM
Cabletech- What is the railroad version program?
Old 10-08-2012, 6:38 PM
setxrailfan The railroad version of software has the ablity for doing extra features that are needed for the movement of the trains.
This also goes that the radios used by the railroad are not a standard off the shelve radio, they are made just for the railroad, but some older radios do show up in the normal world.
Tags
icom programming, mobile install, programming help, uhf
