Bearcom BC100u
w5lsi
Does anyone know what ICOM model the Bearcom BC100u is and if that ICOM programing cable and software will work with the Bearcom BC100u?
Thanks.
-Dorian
W5LSI
RodStrong
West
It looks exactly like the IC-F3001/4001 series radio. Not sure about software, but I bet they use the same cable. Good luck.
cabletech
Puget Sound
The BC100u is the same radio that Icom calls the F3011/4011 and uses all the same accesseries and software.
The differance between the F3001/4001 and the F3011/4011 is the size and the F3001/4001 uses a differant software but the same accessiers.
Go to ICOMAMERICA.COM and check the specs and you will see that they are the same.
