Originally Posted by zane018
I think i have found the squelch adjustment in the program, it was at 80 but honestly i have no clue what to set it at.
It may have a range of 1 to 256, so 80 might be kind of loose. If you write down the existing value, then try it to see how high and low it will go, it'll give you an idea. It sounds like it's set to loose, so adjusting it up will likely help.
Ideally, if you can find the manual method that you can do from the actual radio, that would be easier. The F-4 allowed adjustment on the fly, much easier to set it that way.
