IC-F3GS Software
cabletech
Puget Sound
if you are using 2.2 then you have an update verison. Most changes in version have to do with the program working in Windows.
Don't worry about it.
Colton25
Okay, i'm trying to figure out a way to be able to change the tone on the radio frequency from the radio.
cabletech
Puget Sound
Are you talking about the PL tone? The option that says ctcss/dtcs is were you change the codes.
If using PL then you will get a drop down, pick what you want. If useing DPL, just type the number in; DPL 022.
When all else fails, high lite each item hit f1 for help.
Colton25
yeah i figured it out, thanks
