| ICOM Land Mobile Radio Discussion forum for ICOM land mobile radio equipment such as the IC-F series radios. Please do not post amateur radio topics here. |
11-11-2012, 9:02 PM
Icom 2 Tone Detect Setup
Our FD has several Icom mobile and portable radios. I would like to set up these radios to detect our tones (2 tone system).
It is my understanding that these radios are more than capabile of doing this however I cannot seem to get it functioning right.
Our department uses 4 different 2 tone combinations for different station dispatches. Can I stack all these on one channel so that the radio will be able to decode any of the 4 combinations? I would prefer that the radio didn't beep but just display text identifying which tone was being set off. Hopefully this make sense...
I have the tones and am familiar with navigating the programming software but just can't seem to make the radio do what I want.
Thanks,
Brandon
11-12-2012, 4:03 PM
Brandon In order to due this, you need to setup a differant channel with the 2-tone and then a 'no' tone which will allow you to listen to the normal traffic and then say at night, turn to the 'tone' channel and it will 'open' on the tone.
Check your e-mail.
11-12-2012, 4:07 PM
Ok that helps! For some reason I was under the impression that you could "stack" multiple 2 tone sets on one channel.
Thanks for your time and help,
Brandon, K7KLA
Bluewood Ski Patrol Director
Firefighter/Paramedic, Walla Walla Fire Department
11-18-2012, 11:31 AM
You again! (Snicker)
What version do you have? (see my other post.)
In the F50 V and MCD series, you can stack ten 2-tone decodes on a single memory channel. Just remember that with MDC radios in 'LMR (2-Tone)" mode the radio will stay muted until signalled, and Auto Reset timers can be programmed to re-mute after X seconds. The V versions have both "AND" and "OR" options. I normally program TX-inhibit which prevents accidental 'butt dialing'
Check the attachment.
COML, Public Safety Communications Consultant, Interoperability Crusader, Firefighter, and Slayer of Dragons (aka Proprietary Systems), K9PKE
12-05-2012, 5:41 PM
I have the IC-F50 LMR and I am using software version 2.1
I cannot seem to get the radio to open up. I know I have the right tones programmed although I must not have the rest of the settings programmed correctly.
Thanks,
Brandon
Brandon, K7KLA
12-06-2012, 1:37 PM
Thanks,
Brandon
Brandon: Email me the .icf file.
12-06-2012, 1:39 PM
PM your email address
Brandon, K7KLA
12-16-2012, 12:53 AM
Thanks,
Brandon
Do you know the Tone A & Tone B?
Dell computers SUCK! Dude you jail you can't get a dell
Radios Alinco DJ-X10T IC-F43GT BCD396XT PSR-800
Youtube staugfl1991
12-16-2012, 12:54 AM
Sure do
Brandon, K7KLA
12-16-2012, 1:05 AM
Sure do
cool deal.
Youtube staugfl1991
