Icom 4161 Selector Knob stop removal
mike16150
Hi, does anyone know if I can remove the stop on the 16 position selector knob on an Icom 4161ds. I would like to use the knob to select channels but I have more than 16 channels and also more than 16 zones. I've did this to a Kenwood NX-300 but the Icom doesn't seem to be capable of this.
jeepsandradios
East of the Mississippi
Cant be done. The dial is for 16 channels only. You can setup a button on the side for channel up and zone up. You can still use the channel dial for 1-16 or zone 1-16.
mike16150
Thanks for the reply - I switched some programming around and ended up using the two side buttons like you described and it works perfectly. Now for some research on NXDN and IDAS
