Go Back   The RadioReference.com Forums > Commercial and Professional Radio > ICOM Land Mobile Radio
ICOM Land Mobile Radio Discussion forum for ICOM land mobile radio equipment such as the IC-F series radios. Please do not post amateur radio topics here.
Old 04-18-2014, 8:33 PM
cifn2's Avatar
Default Icom F-4061T for mixed mode?
Purchased an Icom F-4061T off Ebay earlier this week. Got the radio programmed today, but when we did, we have found that with the software CS-F3060 V 1.2 and latest firmware 1.8 their is no option to turn on scanning function of the radio, also there is no ability to label channels as mixed mode they have to be either digital or analog in each bank. Anyone know if there is a work around or solution for this problem?
I see in the specs sheets and manual that it says the radio should scan as well as be able to do mixed mode.
Any help or suggestions is appreciated.
Old 04-18-2014, 9:08 PM
rescuecomm's Avatar
You should be able to assign the scan function to one of the front panel pushbuttons. A quick touch should start the scan. A long press should allow access to the different scan lists. I can't help on the mixed mode as my radios don't have the option boards.
Bob
Amateur Extra Class
Travelers Rest, SC
Old 04-18-2014, 9:44 PM
cifn2's Avatar
Hmmm I wonder if we need to do something different scan is not listed as a button we can assign when we were assigning. Might have to make sure everthing is correct software wise.
Old 04-19-2014, 12:13 AM
MTS2000des's Avatar
The 4061 will not scan in digital mode, when you setup the radio for "LMR digital" it disables the scan function radio wide.
The 4061 does not support mixed mode operation either, these are early (1st generation) iDAS radios, if you want one that supports scan and mixed mode, you'll need to move up to a newer radio such as an 4161 or 4261. Nor does it support encryption (not that this is an issue for ham radio)
iDAS was just born back in 2005 when these hit the market, 99 percent of them don't even have the UT-119 installed. Be lucky you got that the board alone is $200 if you can find it.
All opinions, statements, posts, or information made public are those exclusively of the author, and not those of his employer, contractors or associates.
Old 05-03-2014, 12:05 AM
jeatock's Avatar
V1.2 is the last version of the 4061 software.
Under SCAN|Scan List, I use M3(R.Sel), which is scan, with priority and Tx on the rotary selected channel. Turn text off (blank) to see scan progression.
Digital disables scan in the 4061. The 4161 is a different radio and will do scan any way you want it.
My standard setup in Key & Display is:
Emer- Lock
Side 1- Moni
Side 2- CH Up (Up/Dn is used for User Set Mode adjustments and Zone Selection
Side 3- CH Down
P0- Scan B Start/Stop (Scan A has issues restarting after PTT)
Hold;P0- accesses scan list selection.
P1- Scan Add/Del
P2- Zone
P3- User Set Mode (access Common|Set mode from the radio)
COML, Public Safety Communications Consultant, Interoperability Crusader, Firefighter, and Slayer of Dragons (aka Proprietary Systems), K9PKE
