I have an F4161 which I have successfully programmed. It has an IDAS option installed but I am only using the radio in analog mode.
The radio will scan and will stop on a carrier. But when the carrier drops, the radio does NOT automatically restart scanning after, say, 3 seconds. I need to manually restart the scan using the programmed scan key.
I have spent hours trying different settings. I also used a default "codeplug" just in case the original had some incorrect values hidden away.
With all my other Icom radios I have never had a scan resume problem?
Any ideas?
Maybe its firmware related? The radio is running v2.9 firmware and I am using the latest v5.0 software. Maybe I should use an older software version? Or update the firmware?
Any ideas?
