Hopefully this will suffice...
MEMORY CH
Free – Atr, Inh, Frequency RX, TX, TX Inh, W/N, SQL Tight, C. Tone RX, TX, TOT, RF PWR, PWR Save, Lock-out, Scan, Auto Reset.
CONTINUOUS TONE
Continuous Tone Setting - Tone Burst, CTCSS Reverse Burst Timer, User CTCSS Freq, TX DTCS Inverse, RX DTCS Inverse.
SCAN
Scan List – Scan Type, Primary CH, TX CH, TX Action, Cancel CH, PWR Save.
Scan Setting – Timer Stop, Resume, Talk Back, Fast Scan, Slow Scan, Power on Scan, Talk Back Timer Beep.
COMMON
Key & Display – Key Upper, Lower, Remote Mic Function, Mic Up, Mic Down, Mic A, Mic B, Beep Opening, Low Freq, High Freq, Selection RF Power, Move to Prio A Ch Power SW ON
Set Mode – Value Beep On, SQL Level
Common – Clone Comment 1 &2, Security Transceiver Data Out, Auto Reset Timer A, Timer B, TOT/Lockout TOT Timer, Penalty Timer, TOT Beep, Lockout Penalty Timer, PWR Save Start Timer 1, Start Timer 2, Low Battery 1 Beep, Periods, TX End, Low Battery 2 Beep, Periods, TX End, Beat Cancel, Battery Type, SQL Tight Offset
