ICOM F50V
Rescue20
New York
Hi!
I'm trying to program a F50V with paging tones and I'm having trouble with it. I put the A and B tones in and when it trips it only trips at the end of the tone and not the entire tone. Is there a way I can get it to alert during the entire tone like a Minitor 5 Pager ?
Thank you in Advnace!
RJB
Firefighter6940
Tunkhannock, PA
Hi!
RJB
Yes, check the 2nd tone duration in your two tone settings.. Set it to the lowest it'll go, and it should alert like a minitor.
Firefighter6940
Tunkhannock, PA
Ok thank you! So set the 2nd part to 0?
0.5 somewhere around there.. Just mess with the settings until you get something you like. If you have another radio, just use a murs channel on low settings, and set off the F50V until you get settings you like. It'll be the 2nd Tone Duration or something like that.
Firefighter6940
Tunkhannock, PA
No problem! If you need anything else just let me know! I'm not that familiar with the F50v, but it can't be that much different from the IC-F70
cabletech
Puget Sound
Setting up any device to act as a pager requires that you know what the exact timing is of the tones that are being sent.
Each tone has a certain time duration and there is also a certain time between each tone.
If you do not have this "timing" correct, the device will never alert.
Do you have the ability to make contact with the system radio tech's for the correct tones and timing?
sibbley
Nazareth, Pennsylvania
Not entirely correct. I have several radios and DO NOT have the exact timing or tones from the system admin or radio tech, however, my radios alert every time the tones are sent. One thing I've learned is that the tones can be slightly off and still alert. I used my 346xt to find the tones, and use them in every radio I have. All the radios alert just fine.
Rescue20, I have my F60v set to 0.3 on the 2nd tone. Works pretty well.
RADIOGUY2002
Chicago Burbs
TWO SETTINGS
I was told anything between 0.50 to 0.80 will almost always result in activation. The statement works fine for all my five two toned departments that I opt to listen two in a pager like fashion
sibbley
This is true. The setting on the second tone will result in the time you hear the second tone before or after alert. Longer time equals more time the second tone is heard (ie: at 2.00 you would hear all of the second tone and the alert would come after).
I've found that setting the 2nd tone at 0.3 with a fixed duration on the ringer of 3.00 seems to be closest to a pager. I'm very happy that the F50v/F60v software allows us to change these settings to fine tune to our liking.
