icom f1020 rx audio pin3 of rj45 connector?
va7rc
Prince George BC Canada
HI all, I am playing with a f1020 and according to the info I have
pin3 of the 8 pin modular mic connector should be rx audio?? if so is there a "coffee bean"/solder jumper or some other mod that needs to be done to see rx audio at this pin?
Thanks again Warren
jeatock
090-45-50 W, 39-43-22 N
On the front board:
Soldering CP1 connects pin3 to DISC,
OR,
Soldering CP2 connects pin3 to amplified audio out (parallel the V+ on the front speaker, and also muted when you plug a 3.5mm in the back of the radio)
DON't close both or the magic smoke will escape!
