IC-F2821D Firmware Downgrade
shillson
Weymouth, MA
G'Day! I'm trying to downgrade the firmware in my F2821D, to resolve some P25 issues. I have the firmware application, but when I try to connect to my radio and downgrade, I get an error about not being able to access boot mode.
The configuration file for the firmware app lists the following:
[Global]
ComPort=1
Can anyone provide any insight?
Thanks!
-Steve
jeatock
090-45-50 W, 39-43-22 N
Firmware changes require the genuine Icom OPC1122U USB cable. Serial does not work reliably. An eBay cable may brick the radio.
Read the radio with the CSF1700 software and make note of the com settings. Save the file because the radio will need to be reloaded. The firmware software needs to use the same com port as the CSF program. Selections are in the top menu bar.
The EX-whatever firmware software may not allow you to use com ports above 4, so you may also need to force the USB cable to com port 1~4. Doing that is different for each PC operating system
shillson
Weymouth, MA
Thanks for the info. It's weird that I need to use a USB cable, since all it seems to do is convert USB to serial.
Just have to scrape up the $90 for the cable now... :)
-Steve
cabletech
Puget Sound
What are the issue's that you think a firmware update is needed? Most issue's are in the way the radio is programed and not in the firmware.
