CS-F2000 Programming Manual
masonb
Canada
Hello fellow RR users,
I recently acquired an Icom F1000T & can program conventional frequencies easily enough, but when I get a little deeper down the rabbit hole, I get lost fast. Basically what I need (I coordinate construction vehicles on site) is a quick 'chirp' (preferably at the beginning) of my transmissions so other radio users know to listen up as there are can be many users on the frequency at any given time leading to confusion. So to get to the meat of it, I am looking for a manual or the next best thing.
Thanks in advance,
ScanWI
MN & WI DB Admin
Wisconsin
DTMF
The easiest way to do in that radio without using digital would be send a couple of DTMF tones.
The first thing you need to do is select L-IN under the Log entry in the channel area. This tells the radio to send a DTMF code when the radio is keyed.
0B2CIowfTDVZbfkR2ajh5OGhQXzRDSXZmX1VRT2NXWktDRzQwNUQwYUFhb05BZU9tVDBVMW8
Next go to DTMF > DTMF Autodial
Enter the digit or multiple digits to make the tones. The text does not matter nor does it need to be changed.
Last go to DTMF > DTMF Setting
Adjust the First Timer so the DTMF code does not get cut short when transmitting(user preference)
masonb
Canada
ScanWI,
Sadly I followed your directions without success (also the picture references did not display properly?).
I'll play around with it a bit more, I must be overlooking something simple or possibly turned on an option that is causing a bind. You wouldn't by chance happen to have a compatible .ICF file I could just change out the frequency for, order does not matter.
Also thank you for the speedy reply
12dbsinad
You could enable MDC1200 data burst on PTT push down. If the receiving radios do not have any muting enabled they would hear a nice "Squawk" before you started talking.
Settings are in the MDC section and you enable it per channel on the common screen.
Just a thought.
jeatock
090-45-50 W, 39-43-22 N
ScanWI is heading you in the right direction. It's not that hard, so it must be something simple.
In all of the newer CS-F programs, a right-click on any field will bring up help for that field and link associated fields. However, sometimes the programming 'translated well from Japanese it is."
ScanWI
MN & WI DB Admin
Wisconsin
Here are the photos I was trying to display, I have tested this on a IC-F4161, but I do not have any 1000/2000 series radios right now to try it on. You may need to make sure the the signaling is set to DTMF. If you are still not hearing the tones make sure your DTMF delay timer is long enough.
jeatock
Ah HA!
You appear to be correctly telling the radio to sent DTMF Log/ID Code " ". If everything else is correct, the radio is doing exactly that, and sending nothing.
Try entering "19" in the Log/ID field.
