IC-F6061 frequency
HummerMike
Abbeville, S.C.
I got a great deal on a new IC-F6061 UHF with the remote head kit. Gonna use in my mobile. I'll use for mainly commercial frequencies. I would like to put a few 440 repeater pairs in also. The band split on this radio is the 450 - 512. I haven't received the software yet. My question is, will I be able to program in a 440 frequency with the software with this band split? I know the F6061 comes in a lower split like 400 - 470.
Thanks,
rapidcharger
The land of broken calculators.
Thanks,
Yes but down to a certain point.
I want to say it's something like 440.750.
Below tha, It'll read and write fine but when you go to transmit it'll just blink at you.
Great radio though. Congrats.
HummerMike
Abbeville, S.C.
Thanks ...... just wanted to know if the software would actually program the frequency. I will need down to 441 or so. Hopefully the VCO will still lock there.
HummerMike
Abbeville, S.C.
Good deal .... just wanted to make sure I could get the frequency put in the Radio. My lowest is 441.525. Maybe the VCO will stay locked that low.
Tks,
HummerMike
rapidcharger
Yes. It doesn't complain one bit. The clone editor software doesn't so much as tell you it's outside of the range.
Tks,
HummerMike
I have several of these radios and I've actually programmed th entire 440 band, all the frequencies! In to a zone so I can momitor and so unless you go to transmit down there, you're golden.
Did you get a "d" model?
HummerMike
Abbeville, S.C.
Yes, it is the "D" model. My lowest transmit frequency will be 446.000. Four Fourty Activity around here is pretty active. I'm really a Motorola man at heart. I really like the Mototrbo DMR UHF Ham activity.
HummerMike
rapidcharger
HummerMike
Well now you can try out NXDN, which I personally prefer over dmr.
It's a solid performer and you'll like the relative simplicity.
The Main drawback to owning an icom is the lousy resale values. And from what I've read the newer radios don't yet have a narrowband waiver for hams
wa1nic
Westfield, Ma
There were some inconclusive discussions elsewhere about more recent shipments of ICOM radios not being able to do WFM.
I have personally yet to find one that would not accept the WFM selection but some people claim that they have. To be honest, I go out of my way to find old stuff so that I am certain it will do both modes.
HummerMike
Abbeville, S.C.
Have done some programmimg on the 6061 since I have got it. It has taken any frequency I have put in it so far. Some narrow, some wide. No issues. The only issue I had was that the El chepo E-bay program cables would not work. I had to get a real Icom program cable to make the computer and radio talk. Kept getting "illegal info" with the cheap cable.
wa1nic
Westfield, Ma
After you programmed, did you try reading back out again to verify that the WFM stuck?
The thread about WFM said that it would appear to allow the WFM programming without errors, but it would ignore it and when you read back it would say NFM. If it says WFM when you read back you are good to go.
Rick
HummerMike
Abbeville, S.C.
Hey Rick ................ Yes, I have read it back and works fine. I have one frequency on 441.??? that the VCO unlocks on receive. Put in 442.500 and the VCO locks. Will find a Service manual and see what is involved in tweaking the VCO a bit.
wa1nic
Westfield, Ma
I havnt looked for the 6061 service manual, but I had no problem finding the 5061 service manual online as a PDF.
ElroyJetson
I AM NOT YOUR TECH SUPPPORT.
DO NOT ASK ME FOR HELP PROGRAMMING YOUR RADIO. NO.
Icom software is notoriously uncritical of what frequencies you enter into it.
You can enter VHF frequencies into a UHF radio. Or vice versa. The software doesn't error check the frequencies entered at all. The radio will even try to tune to those frequencies. At some point the VCO won't lock and the display flashes to indicate the out of lock condition.,
It's pretty dumb. But that's Icom.
