ICOM 1721D MDC
Wtxfireguy
Coleman, TX
I have been programming radios for a while now and am working on some Icom 1721D's for our department. I would like to use the MDC function, but it does not come up in the menu for my software.. am I missing something? I have it all listed in the digital menu, but all I want is simple MDC function. Can anyone give me some pointers on what I am missing or if I need different software to get this going.
12dbsinad
It's possible you are using old version software, if so, click model and you should see MDC LMR or something along those lines... Select that. It will however clear all your data out when you switch modes just FYI. You should then see MDC listed on the left column.
Wtxfireguy
Coleman, TX
So just find updated software and it should pop up? I have been using the lmr function but checked under the pmr setting and it was missing in it as well.
12dbsinad
You must be running real old CPS version then. Originally the F70/1700 series didn't have MDC capability. If the old CPS still programs the radio I'm thinking it may have old firmware in it, possibly pre MDC. If that is the case you will need to burn new firmware into the 1721. But try newer version software first. Version 2.2 CPS I believe is the latest.
12dbsinad
I would reccomend contacting the local icom land mobile dealer. They have access to all the firmware and is easily done in just a few minutes. Our dealer does all of our firmware upgrades.
Turn the radio off. Push and hold the first push button and the 4th together while powering on the radio. The revision will display on the screen followed by a bunch of other stuff. What does the revision say?
