F5021 Volume Sensitivity Adjustment
PNWSpeeder
I have an ICOM F5021 installed in a very noisy environment (a rail motorcar). This requires hearing protection and an intercom system from an airplane. The radio audio feed to the intercom is via the external speaker 3.5 mm plug. The audio-out volume control on the ICOM appears to give only a couple of windings of the pot between too soft and painfully loud. Is there an adjustment I can make to the ICOM via software that would change the volume range?
A second idea would be to use an OPC-1939 and pick up audio-out from there? Any suggestions?
If not, I suppose I'm down to wiring in another pot or a resistor between the radio and the intercom.
