This is somewhat of a silly question, and I am pretty sure I know the answer but I figured I would see what input I might be able to get.
I bought a group of older IC-F60 radios. They programed up just fine and have been using them with a repeater system for a couple of months. Recently I had issues with fringe repeater RX/TX, that I thought was repeater desense. After some testing it appears that some of the radios have weak TX at range (don't know if it is power or off freq). No noticeable issue close in, but major difference in TX (repeater RX) between units at range.
All HT units have no noticeable difference in RX (repeater TX) at range. But about half of them can barely hit the repeater when at range, while in the same spot another F60 has no problem hitting the repeater with low noise. I swapped out antenna etc, but the common factor was the specific HT. At the exact same physical location at the same point in time, a good one hit the repeater with low noise and good signal (regardless of antenna), while a bad one was hard to hear out of the repeater with a lot of noise regardless of antenna.
Obviously my first thought was that the bad HTs have drifted and just need to be adjusted/aligned. Unfortunately I don't have the cable jig for that or all the necessary equipment so I am looking into taking them to a radio shop.
My question is if it is possible for radios to go "bad" such that while they basically work, components degrade such that they can not be adjusted back into spec or alignment?
It is somewhat of a silly question because with electronics, just about anything is possible, but often either they work, or something quits and they don't work anymore. I am wondering how likely it is for these radios that performance just degrades and it can not be restored?
Note: All HTs are programed from the same icf file, and using the same channel etc..
