F70DT Programming Help
rja1
Enfield, NH
Hi all,
Finally picked up an ICOM F70 DT (with P25 & a bunch of other B&W that I will never use). Actually, 2 F70 DT's, in great shape & reasonably priced, from a good guy, who is also a member here. I've got a bunch of 2 Meter repeaters programmed into zone 2 and zone 1 is used to monitor New York State Electric & Gas, a state wide trunked P25 system. I've programmed all the voice channels from the entire state into zone 1.
Some frequencies are used as CC's in one location and as voice channels in another location. This radio, unlike some P25, non trunking radios, will not pass data burst audio, only voice. Most NYSEG locations have only one or two voice channels, so it works pretty well, even though it's not a trunking rig.
I'll be the first to admit that I am a computer dummy. I have OE ICOM SW (V 2.2.0.10) & OPC-966U programming cable. I need help with making this HT scan. I assigned the P0 button to scan, but when pushed, the display says scan, but it just sits on channel 1. If I hold down P0, it will scan all the channels in zone one, but as soon as you let go, it stops.
I'd be most grateful if someone more familiar with the rig could talk me through what I have to do to get this rig to scan .
The other thing that has me stumped is how to get zones 17 to 32 to show their contents. The knob up top shows zones 1-16. Haven't figured out how to get it to show zone 17-32. Any ideas / suggestions ??
Thanks & 73,
Bob
N2OAM
SirJ
Intelligence Everywhere!
Los Angeles/Ventura County
The knob is set for channels not zones.... If you do zones then you get 16. I have the ft-70dt with all the mods too. Scanning is easy in fact this radio was easier to program then the Motorola xts5000 which I have been using for over 5 Years. I'm a moto dealer. So please explain in detail what ur issue is with the f70
Sent from my SM-G900V using Tapatalk
