FR3000/4000 Programming Cable
BlueDevil
WA
I have been unable to read or write a few Icom Repeaters (2x-FR3000 & 1xFR4000) that I recently purchased. I am using the CS-FR3000 V1.4 software. I have also been using an Icom OPC-1122 USB Programming cable because I was told that would work. I have a feeling that I maybe using the wrong cable since the cable does with with other Icom Mobile Radios.
Any thoughts or suggestions?
ElroyJetson
I AM NOT YOUR TECH SUPPPORT.
DO NOT ASK ME FOR HELP PROGRAMMING YOUR RADIO. NO.
I do not recall the part numbers but the programming cables I used to program FR3/4K repeaters is a two piece cable. One is the same cable used to program all the Icom portables that use a 1/8" phone plug, (3.5mm) and the other is an adapter cable that is a female 3.5" phone socket on one end and an RJ11/14 type connector on the other end.
The cable used on Icom mobile radios has the same RJ11/14 plug on the end of it but it emphatically DOES NOT WORK on the FR3/4K repeaters.
You can not use the mobile cable to program these repeaters. You use the portable cable and the adapter.
I don't have the part numbers, sorry.
