Go Back   The RadioReference.com Forums > Commercial, Professional Radio and Personal Radio > ICOM Land Mobile Radio
ICOM Land Mobile Radio - Discussion forum for ICOM land mobile radio equipment such as the IC-F series radios. Please do not post amateur radio topics here.
Old 09-20-2017, 12:05 AM
Default IC-F121 w/OPC617 for APRS or TNC
Has anyone tried using an Icom F-121 with the OPC 617 serial adapter for APRS or TNC use?
Old 09-20-2017, 10:10 AM
W9BU's Avatar
Lead Wiki Manager
The OPC-617 is not a serial adapter. It's an option cable that gives you external access to some of the pins inside the radio.
I have an Icom IC-F1020 that I have used for packet and APRS while connected to an external TNC. The F1020 uses the same OPC-617 cable that the F121 uses.
Attached is the pin-out of the OPC-617 from the IC-F1020 manual. Just match the pins in the OPC-617 to the radio port pins on your TNC.
Lead Wiki Manager and Forum Moderator.
"The whole world's living in a digital dream. It's not really there, it's all on the screen." -- WB6ACU
Old 05-18-2018, 3:15 PM
DODGEIT's Avatar
I have a didgipeater set up with a Icom f-121S. I had to get a cable that used the mic jack and the speaker jack. I got one from Associated Radio Communications CAB K101 Now that is for a Kantroniics KPC-3. It is in service here at a local hospital.
