Go Back   The RadioReference.com Forums > Commercial, Professional Radio and Personal Radio > ICOM Land Mobile Radio
ICOM Land Mobile Radio - Discussion forum for ICOM land mobile radio equipment such as the IC-F series radios. Please do not post amateur radio topics here.
Old 09-26-2017, 11:15 AM
Default IC-F30GS Speaker Mic Issue
I own 3 IC-F30GS radios. Recently I decided I wanted to add a speaker mic for each. Only one seems to work with the accessory. I've verified the speaker mics all work. I just can't understand how two won't work but the other will. It's been a long time since I programmed these but each was cloned so I can't imagine it's something in the programming but I'm scratching my head here. Any suggestions?
Old 10-02-2017, 5:16 PM
First thing that comes to mind is you cloned from the one that works.. may have not cloned settings/preference
Sent from my SM-G903W using Tapatalk
Old 10-02-2017, 7:44 PM
I went back and re-cloned them... still nothing. The mic works but not the speaker. Perhaps one of the pins are bad on the radio itself?
Old 10-02-2017, 8:56 PM
More than likely it's the accessory connector on the radio itself. Some of the older radios did not use a flex cable and directly soldered to the board. Can't remember if the F30 falls into that category, But for sure a bad design.
Old 10-04-2017, 1:02 PM
I agree but the accessory connector is also used to clone and that works. Itís used for the speaker mic and the mic works. Itís got to be just one or two pins bad that are for the mic. Any one have a schematic showing the pinouts? Would it be worth the money to get repaired at my local 2-way radio repair shop?
Old 10-04-2017, 5:12 PM
Just to clarify, you get no RX audio from the speaker mic but transmits fine?
It could be bad solder joints on certain pins. It's a relatively easy fix if someone is good with an iron.. But don't spend much as that is a 15+ year old radio and wouldn't be worth it.
Old 10-05-2017, 6:54 PM
Correct
Old 10-11-2017, 12:16 PM
Iím going to search and possibly create a new post but here is my follow up question. I bought an F33GS and need to know. Is it possible to clone Icom radios that use different versions of the programming software? I have F30GS that Iíd like to clone to a F33GS. I have the cables and software for each. I just donít want to manually type in 180+ channels and the respective data. Thank you.
