Go Back   The RadioReference.com Forums > Commercial, Professional Radio and Personal Radio > ICOM Land Mobile Radio
ICOM Land Mobile Radio - Discussion forum for ICOM land mobile radio equipment such as the IC-F series radios. Please do not post amateur radio topics here.
Old 07-08-2018, 12:12 PM
Default IC-F9511 & IC-F9011 Technical References?
Hi!
I'm volunteer comms support for our county Search And Rescue. I just purchased new-to-me radios
ICOM F9511 & F9011
I have downloaded everything I can from ICOM, but I cannot find anything technical. I would like to find a programming guide, menu guide, service manual, and anything else.
For example, how does one find out what firmware is on the radios?
Thank you!
Jackie
Old 07-15-2018, 9:41 AM
MTS2000des's Avatar
Icom makes service manuals and bulletins available to their dealers, not directly to end users. Most Icom radios a combination of key presses during power on will display firmware version and D-REV. On the iDAS radios like the IC-F4061, it's holding the P0 and P3 keys down while turning the radio on.
Not sure about the P25 gear but give it a try.
NO I will not help program your trunking radio. All opinions are exclusively those of the author and in no way reflect the position of his employer, contractors or other parties.
Old 07-22-2018, 8:55 AM
Default Thanks, MTS2000des
Thanks! Holding the P0 and P3 keys down while turning the radio on worked for the F9511.
I have found a few more user guides and such. Sigh. Why so difficult?
Old 07-22-2018, 1:21 PM
The users guide is pretty much the manual that comes with it. As far as operation, the radio can be configured in so many ways it's impossible to make a manual that covers all the bases. There are P25 conventional and P25 Trunking models, some with AES/DES encryption, etc, etc.
Programming help is included with the CPS under help files. But, if you're programming an advanced radio such as this it is under the assumption you know the basics of radio programming. Getting into P25 Trunking subscriber programming is not something designed for the novice (not saying you are).
Most of the technical stuff is only provided to the dealers, like most other major radio brands.
Old 07-22-2018, 3:19 PM
Wink
Yes, I know there are a million combinations of settings.
However, before I slapped on a programming cable, I needed to know the firmware.
Also, I want to buy a good antenna for it, so needed the specs.
As far as I can tell, you can program this thing to have coffee ready!
Old 09-12-2018, 12:06 AM
Im a Icom Dealer PM me if you need help with those radios
Tags
f9011, f9511, lmr, technical assistance
