Diamond antenna questions for R-20 radio
I have noticed that a lot of R-20 owners like using the Diamond RH77CA antenna. I am thinking of buying one, however the Diamond RH951S High Gain Tri Band antenna also looks interesting.
Apparently the only difference is that the Tri Band adds receive capability up to 1300 MHz and beyond, whereas the RH77CA has receive capability only to 900 MHz.
I would like to hear opinions from anyone who has used the Tri Band antenna on their R-20. Are any of you even listening to anything beyond 900 MHz on your R-20?
For those of you using the RH77CA, did you choose that antenna because you figured that you can't receive anything above 900 at your location or was it because there is a $20 price difference between the 2 antennas?
Thank you in advance for your input.
