Go Back   The RadioReference.com Forums > Scanners and Receivers Forums > ICOM Receivers
ICOM Receivers A forum for the discussion of all ICOM scanning radios and receivers.
Old 01-23-2009, 12:43 PM
eraweeb's Avatar
Default RH77CA Diamond on 800 MHz?
Thank you to those who answered my previous questions on Diamond antennas.
Since a lot of you are using the Diamond RH77CA on your handhelds, how does it receive on 800 MHz?
Thank you.
Old 01-23-2009, 12:48 PM
hoser147's Avatar
Not bad, It doesnt preform as well as a band specif antenna such as the RS 800
Good Scanning Hser
http://www.radioreference.com/apps/audio/?feedId=165
Old 01-23-2009, 01:19 PM
eraweeb's Avatar
I wonder how well the Diamond RH951S Tri Band antenna works for receiving 800 and 900 MHz since it is tuned to transmit up to 1295 MHz?
That one must be fairly new. I haven't been able to find anyone who has tried it out yet.
Bummer!
Old 01-23-2009, 04:41 PM
icom1020's Avatar
I've never been a big fan of a broadband HH antenna for 800 unless its in an urban environ. Look at the pictures people here have of their shacks. You don't need 20 radios but dedicating one radio to 800 and another to a lower spectrum is what I do at home. In the car the only mobile mount tri-band I have found that works decent on 800 is the Larsen "Special"
Old 01-23-2009, 10:22 PM
On my pro 96 I use the rs800 antenna. I tried others including the diamond RH77..
I scan 800 digital and a few vhf high for fire.
The RS 800 was a clear winner for me because I was more intrested in the 800 and the fire frequency towers were close by.
The Diamond did pull in the fire freqs better but the 800 suffered significantly plus the Diamond is a long bugger and when carried inside my coat it tended to want to infiltrate my nose when I looked down.
If you have some friends with different antennas then expierment and pick what works best overall.
You should try antennas for several days because the propagation may change day to day between bands.
If you wear your scanner on your belt your body can really attenuate the signal from certain directions.
Hoofy
"A computer once beat me at chess, but it was no match for me at kick boxing."
Old 01-26-2009, 03:48 PM
N1SQB's Avatar
If you want the best performance on 800, get an antenna cut for 800. Dont waste your time and money getting multiband antennas. This is the one I use on my Pro-106:
800 mhz Scanner Antenna radio shack pro 164 96 97 - eBay (item 140292829995 end time Jan-11-09 11:57:17 PST)
works slightly better than the RS one.
Manny
MANNY / N1SQB- AMATEUR EXTRA CLASS
IN GOD WE TRUST! EVERYONE ELSE,WE MONITOR.....
Similar Threads
UFA / VECC Fire 16? bneilson Utah Radio Discussion Forum 17 10-17-2008 04:39 AM
800 Mhz Preamp ( In house signal amp ) mancow Antennas and Coax Forum 38 09-20-2008 01:11 AM
800 MHz cell antenna outperforming VHF antenna res6cue_dot_com Antennas and Coax Forum 31 06-08-2008 12:15 AM
RS 800 mhz ducky xpawel15x Antennas and Coax Forum 4 10-19-2007 11:08 PM
For Sale: ProVoice System LPE-200 800 MHz rescue161 Old Classifieds Archives 40 11-11-2006 07:46 PM
