Go Back   The RadioReference.com Forums > Scanners and Receivers Forums > ICOM Receivers
ICOM Receivers A forum for the discussion of all ICOM scanning radios and receivers.
Old 01-29-2009, 10:59 AM
Default How to control Icom-PCR1000 remotely
I need a little help with the experts in this forum. I have an Icom PCR-1000 running with either Scancat, Probe1K, or TalkPCR. on my XP desktop at home. I would like to contol it remotely( change freqs, scan, etc) from my work desktop and be able to listen to listen to it from my computer running also XP at my job. I know it is possible but I cannot find any info on the setup. Your help is greatly appreciated.......Rich
Old 01-29-2009, 12:27 PM
n9mxq's Avatar
RemoteHams.com | Home or you could use RDP and a streaming software.
Too many radios.. not enough time...
At one time Amateur Radio was considered Freebanding..
Old 01-29-2009, 01:01 PM
Thanks for the quick response. I will look into it, and report back the success to the forums.
Old 01-29-2009, 01:27 PM
Default other option
You might run into a problem with RDP depending how your IP address is assigned to your home computer. Also, depending on where you work, it may be firewalled.
I have used logmein to access a remote system and it does support audio however it is VERY dependent on connection speed. On the plus side, they have a demo so you can try it out and see if it works for you. Another one is connecttomypc. I havent tried that one but it should be about the same.
Old 01-29-2009, 04:03 PM
scancapecod's Avatar
ScanNewEngland Webmaster
Send a message via Yahoo to scancapecod
Google PCR Remote and PCR Server. You'll need to stream the audio portion separately, but once you overcome that obstacle it'll work very nicely for you. If you don't mind an audio delay, Windows Media Encoder will probably do the trick for that. All of the software is free.
Scott - Scan New England Webmaster
Old 01-29-2009, 09:21 PM
Thanks for all the responses. I'm sure members can apply this to different scanners also. Being that there is a host of broadband products & cellphones, it would allow members to access their scanners at home while they are at work, driving, etc.
Similar Threads
OFFICIAL NYSEG P25 System Thread rbm New York Radio Discussion Forum 237 10-12-2009 06:18 PM
R2500 Spectrum & Trunked System Analysis Issues offsite ICOM Receivers 21 09-19-2008 03:35 AM
Control Icom outside of App? ecuguru ICOM Receivers 3 09-06-2008 10:52 PM
FS: Icom IC-PCR 1000 PC control receiver shortwaveman Old Classifieds Archives 3 08-14-2008 09:55 PM
Unitrunker with Icom PCR1000 kd5dga Trunking Control Channel Decoding 2 03-15-2008 09:39 PM
