Originally Posted by eraweeb
That is really cool! Obviously you are figuring out the R-20 much better than I am. I am having a problem trying to figure out something that should be pretty basic. Hopefully someone can tell me how to do it.
I just want to put 2 different freqs up on the display and then search between them. Hopefully when it reaches the end of the range it will continue searching from the beginning again. And I would think that I should be able to stop on a freq to listen and then resume scanning / searching again through that same range.
Can anyone tell me how to do this? If so, thanks in advance!
Using Icom CS-R20 software there is a place that you can put 2 different frequencies. It's call Program Scan Edge- here you can program up to 25 sets of frequencies .Example 00A 150.00 - 00B 159.0 then press and hold the DUALWATCH , this will put you in VFO mode . Now press and hold the MODESCAN key and you will see SCAN in the display. Continue holding the MODESCAN key while turning the A DIAL . You will see SCAN:ALL / SCAN:BAND SCAN:PROG-01/ SCAN:PROG-02
"SCAN" really means search in this setting. Now if you HOLD DUALWATCH Key and use these same steps -this will let you search 2 sets of Scan Edges at once. The A DIAL controls the bottom frequency set / B DIAL controls the top frequency set. Remember to use the MAIN/SUB key if you want to change step size or mode . Sorry if I confused anyone -
