Go Back   The RadioReference.com Forums > Scanners and Receivers Forums > ICOM Receivers
ICOM Receivers A forum for the discussion of all ICOM scanning radios and receivers.
Old 02-16-2009, 08:13 AM
Send a message via Yahoo to 2ManyToys
Default Does all Icom R-5 software suck?
(partial repost here)
I bought & have tried to use IC-R5 programming software w/o any luck. Also tried the tk5 but couldn't get it to run w/o crashing (on two different PC's).
This little bugger is kicking my a**. I've spent a number of hours trying to load frequencies & other then the default config. provided with the IC-R5 software I can't. I hate to surrender but the R5 may have to go on the block. 1st electronic gadget that has ever beat me.
Here's the main issue. I can load a single .icf file, either the default freqs. or a .icf file downloaded from the Percon site. But I'm not smart enough to ADD/COMBINE frequencies to an existing file.
What I want to accomplish is to load the default config. & then add additional groups of frequencies from the Percon database. But I'm unable to ADD from the database. When I import the files they just overwrite the current frequencies. Plus AFAICT there isn't a way in IC-R5 to select more then one line/frequency at a time. Rather then select a bunch of frequencies to move them to other channels/banks, it must be done one-by-one.
Then I found a download of the OEM Icom R-5 software. Worked for 2 hours trying to get that software to 'find' the R-5 (yes, I changed the com port to 2, has to be on port 1-4). So I can't comment on the OEM software yet.
One thing I'm wondering about, is my programming cable. I got it with the radio used & it isn't the OEM cable, appears to be a eBay cable. I wonder if I ordered an OEM USB cable if I could connect with the OEM software?
Grrrrrrrrrrr Anyone want to buy a Icom R-5?
Too Many Toys
Uniden BCD396T / BCT15 / BCD996T / BR330T
Icom R5
Drake SW8
Old 02-16-2009, 10:29 AM
N8IAA's Avatar
It could very well be. I have never bought a cable from E-bay for my radios. I have always used the ones that came with the software. Have had many Yaesus, Icoms, Kenwoods, and many scanners. Original is always the safest (not neccessarily the cheapest) way to go. I know that others have made their own cables and bought cables off of the internet and they work.
Just my 0.02 worth,
Larry
Oh, and yes, Icom software sucks
Pro-106, Pro-163, Pro-99, Lafayette 200A, ScanFare VHF 4Ch Xtal, FT-60R
Old 02-16-2009, 05:55 PM
burner781's Avatar
Icom software does suck but with the OEM software and Icom usb cable I have never had any issues with connectivity or with the software running. Its very stable but its very bare bones.
Using an Icom R5
Motorola Sabre IE
BC895XLT
BC890XLT
BCT15
BCD396T
BCD996T
BC200 XLT
Old 02-24-2009, 08:02 PM
Default OEM Software for R5
Could someone please post a link for downloading the OEM software for the R5.
Edit:
Never mind. Did not realize that the OEM software was the CS-R5.
Old 03-25-2009, 10:07 PM
I have the CS-R5 and a UniversalRadio cable and yes, it sucks... I have been going about it with the one-line method you mentioned above and it seems to work fine, however, I've only had my radio for about 2-3 months.
In general, I'm learning that the user interface on the R5 (software and hardware) is not made for "grab and go", but instead "load ahead of time and don't change"
Old 04-07-2009, 08:29 AM
With your OEM software, are you using a USB cable?
I am using CS-R5, if you are you might need a Serial-USB software patch to enable the software to recognise the USB conection.
Mine connects on COM port 6.
But you are right, it's a right royal PITA of a radio. Wish I'd never bought mine!
Cheers.
Old 04-07-2009, 10:58 AM
I was having crashing issues with Tk5 when I first used it. But I figured it out after reading ALL of the documentation. (It's actually pretty well written.) It was a few years ago but in my case the crashes were due to a buggy USB-to-RS232 driver for my USB-to-ICR5 cable.
Old 04-21-2009, 12:59 PM
radioaustralia's Avatar
DB Admin for Australia
I've only ever tried the "IC-R5 Programmer" from ic-r5.com
It does the job quite well, although there are two annoyances that could be fixed. These are:
1) When moving channels up or down have the page move in the appropriate direction.
2) When deleting frequencies hold the position, it currently jumps back to CH #1
Issues will vary between people, it all depends on what your custom to.
Similar Threads
Icom f60v (software CS-F50V/60V) 7586 ICOM Forum 0 02-11-2009 09:54 PM
FS: Icom IC-R5 Unblocked Communications Rcvr + Software rja1 Old Classifieds Archives 4 02-04-2009 11:09 PM
wtb or wtt: ICOM T90A Software... DocDaddy Old Classifieds Archives 0 02-04-2009 02:46 PM
WTB Icom Software for V8 and U82 peterjmag Old Classifieds Archives 0 02-01-2009 05:04 PM
ICOM PCR-100 Compatible Software GreatLakes Scanner Programming Software 5 02-26-2007 04:51 PM
