Separate Streams from PCR-2500?
Hi,
Has anyone been able to listen to two different streams coming from the PCR-2500 at the same time?
Primarily so I can stream two different audio feeds to two different applications.
The thing is, it only looks like you can use it to monitor two different frequencies, not simultaneously listen to them as two unique feeds.
thanks!
