Go Back   The RadioReference.com Forums > Scanners and Receivers Forums > ICOM Receivers
ICOM Receivers A forum for the discussion of all ICOM scanning radios and receivers.
Old 06-05-2009, 05:01 PM
Send a message via Yahoo to majestic36
Question Problem With My Icom IC-R71E Receiver
Hi i just bought a IC-R71E receiver and when i went to look at before i bought it it seemed to be fine
so i brought it home pluged it in and it looked fine for around 20 mins
Then it just switched its self of and there was a burning smell around the ac power pack so i pulled it apart and a fuze had gone i repaced it with a 2A and that blew up so i added a 3A and it stays on now so i think that was down to rain getting in when i left his house with it to go to the car
Anyway now it stays on all the numbers are out of range and theres a buzzing sound from the frount display transformer and only low audio in FM the tuning knob clockwise only moves the numbers up once and works antyclockwise
So after reading for hours on the net it pointed me to a faulty battery on the ramboard as it gives all the same symptoms but i checked the battery and its showing 2.9v its ment to be 3.5v so do you think like i do that the ramboard is at fault
cheers
Old 06-06-2009, 05:33 PM
i have just had the power supply apart and found that one of the legs on the
voltage regulator had broke though the track so wasnt conected so i scraped the track back and resoldered it but its just the same so do you think this voltage regulator may of blown or wouldnt the power supply work at all? as in dead no power
Old 06-08-2009, 10:47 AM
I have 14.3 volts coming from the power supply so thats ok i have looked over every board for burnt parts and bad joints and found nothing it has me stumped
By the way i feel like im talking to my self here someone must have something to say to help me out?
Old 06-08-2009, 10:58 AM
ridgescan's Avatar
I don't have anything productive to offer you I immediately felt bad when I read "burning smell" as to me that could mean an entire circuit frying without the benefit of that fuse link. How wet did you get the radio that day? The burning smell to me means a full dose of voltage got at the wrong spots and got them hot enough to burn. I at least hope someone with decent tech knowledge will come here and pick your brain to get at an answer.
Uniden BC785D
Uniden BC350A
ICOM IC-R75
ICOM IC-R71A
dual Diamond D-130Js on the roof
...being "comfortable in my delusion"-THANKS!!
Pro 2066 in the truck with glassmount
73s-I am Frank
Old 06-08-2009, 12:19 PM
Hi i dont think it was down to the rain now as i found the function button led flowting around in the front pannel so im guiesing that has shorted something out
But with a short and a burning smell comes components that can be seen to be gone but i just dont see anything :-(
I have orded the replacment ram board from here Roberto Nardo, IK2RND's Replacement ICOM RAM Board for ICOM amateur radios of Roberto but he said he cant post untill the 10th so i will have to wate to find out if it is the ram board thats making trubble for me
Old 06-08-2009, 02:22 PM
pyeman99's Avatar
It's not the ram board,that only takes a very small current micro amps.You really need to take it to a repair company,seeing you live in the UK ring Icom they are very helpful & it's still a reciever worth fixing.I replace the RAM battery on mine before it failed,it was running ok but had 2.6 volts,still held the operating system ok.Good Luck.
Old 06-17-2009, 11:41 AM
Update i received my new ramcard today and the receiver is alive again WooHoo BUT i cant store any of the 32 memory chanels if i store say 27.5550 it rights to all 32 chanels
Also in FM i get loud noise but dont pick anything up and if i switch to any other mode theres no noise from the receiver and no received sations
So what do you think it might be now ???
cheers Leo
Similar Threads
Fs: Icom Ic V-8 llllllllll Old Classifieds Archives 3 03-08-2008 08:11 PM
MINT Icom R7100 receiver 89gta Old Classifieds Archives 2 11-26-2007 03:01 PM
FS: Icom IC-R71A Receiver $325 + Ship CONUS scancapecod Old Classifieds Archives 0 06-20-2007 12:33 PM
FA : ICOM IC - R100 Receiver / scanner dconti Old Classifieds Archives 1 10-31-2006 12:33 PM
