Just ran a test on the BC-149A under a "kill-a-watt" meter:
Under no load / idling: 2 watts
Charging: 6 watts
Charge and operations: 7 watts
Since I only use the adapter for charging and not permanent use, I opted for a much smaller, lighter, and cooler switching supply. Both the R20 and RX7 use a RS "adaptaplug C". Here's a rundown on the #273-333 and 273-029 switchable voltage adapters (both similar only the 333 is rated 2A and the 029 rated at 1A. Results are similar:
(note: the 273-333 comes with 3 adaptaplugs, one of which is the "C" size.) The other adapter I had to get the plug separately)
No load / idling: 0 watts
Charging: 2 watts
Charge and operations: 3 watts
However, since they are switching, there is a bit of switching noise heard on BCB and HF AM. 30 mhz+ is not a problem. The antenna I used was basically a few feet from the adapter, so perhaps a remote antenna, with chokes on the feedline might reduce this.
For me, I travel with these switching supplies just for recharging, but the less efficient BC-149A linear supply is much quieter if you use these portables as fixed stations and listen to HF.
