Go Back   The RadioReference.com Forums > Scanners, Receivers and Related Equipment Forums > ICOM Receivers
ICOM Receivers - A forum for the discussion of all ICOM scanning radios and receivers. Please use another appropriate forum for transceivers.
Old 12-02-2005, 9:45 AM
Default ICOM T7H cable pinout
Anyone know the pinout on the DB9 to the 3.5mm connector to make a programming cable?
Old 12-02-2005, 9:46 PM
Al42's Avatar
There are shematics all over the web - it's not just a cable, there are active components.
Old 12-04-2005, 9:14 PM
Could you point out just one?
Cuz I can't locate any.
Old 12-04-2005, 10:01 PM
Al42's Avatar
http://www.starrsoft.com/software/Wi...yourselfcables
http://home.hvc.rr.com/bpetrow/ about halfway down the page
Old 12-04-2005, 10:26 PM
N4UYV_Al's Avatar
Originally Posted by Al42
That's for the Icom T7H?
Retired Vol. FF, 911 Oper/Disp Berkshire County Comm Ctr, Comm Off. Mass Emer Mngmnt Agency. General Class Amateur N4UYV
Equip:Icom IC-706mk2G,IC-729,IC-2000H,IC-V8000,IC-2100(2),IC-T7H(2)
Old 12-05-2005, 11:06 PM
Al42's Avatar
Since I don't have one I can't be sure, but if the Icom uses a 1/8" earphone jack (anywhere from 2 conductor to 4 conductor) it should work. The generic cable is a 5 (+/- 1.5) volt to RS-232 level bidirectional cable running a single pair on the low voltage side.
Old 12-05-2005, 11:17 PM
The ICOM T7H uses a 3.5mm 3 contact plug.
Any other sources that mention the T7H in specific?
Old 12-10-2005, 10:55 PM
Hamradiostuffing's Avatar
give me your email address I have copy of the schematic for the cable that I know works.
