| ICOM Receivers A forum for the discussion of all ICOM scanning radios and receivers. Please use another appropriate forum for transceivers. |
01-16-2013, 9:20 AM
This R7100 is over my head
I haven't got the slightest idea how to operate the Icom IC-R7100 receiver I inherited. The only thing I've figure out so far is how to receive WFM on a 6' wire antenna. I've ordered a D3000N antenna but I thought I would see what I could receive with a short wire antenna.
01-16-2013, 10:43 AM
Lead Wiki Manager
How do you have this 6 foot wire connected?
Depending on how far away you are from the transmitter, you should be able to receive the NOAA weather broadcasts in the range of 162.400 to 162.550 MHz. You will have to change the mode from WFM to FM. The NOAA weather stations are usually a quick and easy test that the receiver and antenna are working.
From there, you should be able to find aircraft in the 118-136 MHz range in AM mode, amateur radio in the 145-148 MHz range in FM mode, railroads in the 160-162 MHz range in FM mode.
Lead Wiki Administrator
Moderator for the Radio Reference Amateur Radio Forums.
"The whole world's living in a digital dream. It's not really there, it's all on the screen." -- Joe Walsh WB6ACU
01-16-2013, 11:02 AM
I've got a ground wire attached to the back of the unit. The 12ga. wire antenna is soldered to a PL259 and then connected to a SO239-N adapter.
I have been able to listen to the NOAA weather station very clearly.
Is there such a thing as a list or chart of frequencies and what they are for, like railroad, aircraft, etc? What about this? Does it cover everything?
http://transition.fcc.gov/oet/spectr...e/fcctable.pdf
01-16-2013, 12:45 PM
Have you checked the RR database for your area Might give you some frequecies to plug in
Larry
Digital/Analog scanning and hamming
01-16-2013, 2:59 PM
Sure have! Only the local scanner frequencies.
01-16-2013, 3:29 PM
Just google icom r7100 and download the PDF file manual. it will show you all you need to know about this receiver.
Good luck
K3CFC
Don't confuse my personality with my attitude.
My personality is who I am.
My attitude depends on who you are.
01-16-2013, 3:49 PM
Lead Wiki Manager
What did you expect?
The IC-R7100 is a VHF/UHF receiver. You use it to listen to the same frequencies you'd hear with a scanner.
01-16-2013, 3:50 PM
Originally Posted by k3cfc
Just google icom R7100 and download the PDF file manual. It will show you all you need to know about this receiver.
Good luck!
K3CFC
I've already done that. The information there is greek to me. I don't understand most of it.
I am a disabled veteran and was hoping this receiver would give me something to do. Unfortunately the meds that VA has me on makes it a little difficult to concentrate.
Thanks!
01-16-2013, 4:39 PM
Program Steps:
1. Use MEMORY- CH DOWN & UP buttons to select what channel number (000-099) to be programmed.
2. Enter frequency (162.55)
3. Make certain FM N is displayed, if it isn't, press the FM/N key
4. Press ENT (yellow) key
5. Hold MW (Memory Write) button down for three seconds, doing so will cause (162.55) to be retained for selected channel number in step 1.
After you've entered multiple frequencies, use the DOWN & UP to select the channel/frequency you want to monitor.
Practice entering all weather frequencies into different channels using the same above steps.
01-16-2013, 5:09 PM
Thanks!
I am sorry to hear that. let me say this my hat is off to you and thank you for your service.
i will help you all i can.
K3CFC
01-16-2013, 5:20 PM
Originally Posted by Squad10
Program Steps:
There is only one weather channel 162.450 in my area. Can you mix ssb, am/w, wfm, fm/w within the same scan? Not sure if I'm asking that question correctly.
01-16-2013, 5:32 PM
Yes.
Use aw/w for aircraft band frequencies 112-118 and military bands, fm/w for fm broadcast band 88-108 and fm/n for pretty much everything else.
Be certain to perform my step 5 or frequencies will not be retained.
01-16-2013, 6:26 PM
The R7100 is a great receiver! You can program whatever freq or whatever mode(FM FMN AM SSB) into any channel. You may not scan as much as have your favorites in memory and quickly be able to monitor them. It comes close to specs of a commercial grade receiver.
Read these reviews and pick up bits of info about its use and features...
http://www.eham.net/reviews/detail/872
While you only have one NOAA weather channel in use in your area, you have 1000 memories in the radio. Go ahead and put all the weather frequencies in, as once you add the Discone, you may find signals from other areas and can keep tabs on approaching weather or events not in your immediate area...
Cleve/W5CEM
01-16-2013, 6:35 PM
Learn it, know it, love it. You got a real good one there. Give it a good antenna, it deserves one. It'll pay back in outstanding pro receive quality void of all that front end overload crap.
Icom R-7100 Product Reviews
You lucky dog you
If I were you, I'd sneak a discone outside.
Unidens BC785D, BC350A on a D130J
'54 Hallicrafters SX-88 #127, Icoms R71A&R75 on 50' random wire @40' SW will never die
RS Pro 2066 in the truck to glassmount tribander
01-16-2013, 7:25 PM
If Air Force One is ever in your area, the R7100 SSB and TS 0.1 may come in handy. It's the reason I bought one in the 80s.
01-17-2013, 3:46 AM
I'm not sure where to start saving the channels. There are three smaller digits to the right in the display that start at 000. Is this where I should save the first frequency? If not what are the 000 for?
One thing I haven't been able to figure out is that I can't seem to get any local 11 meter reception. The 11 meter band should be on AM correct?
I should also be able to receive 10 meter SSB as well right? Is it because I don't have the correct antenna?
01-17-2013, 4:23 AM
Thanks for the link. It appears there are lots of satisfied R7100 users.
01-17-2013, 4:44 AM
I will help you all I can.
K3CFC
Thank you Sir! It didn't turn out like I had planned. I was a career soldier with 7 years active duty. I was going for 20 years of service but the combat related disability put a stop to that. I have not been very prepared for it but I've got to make the best of it.
01-17-2013, 5:20 AM
Lead Wiki Manager
It could be your antenna or just a lack of activity in your area. Do you live near a major highway or a truck stop? Yes, CB is AM with some SSB.
Yes, your radio should be able to receive the 10m amateur radio band. Activity on 10m is generally sparse unless propagation is good.
If your interest is 10 or 11m, a dipole antenna (which has horizontal polarization) or a vertical antenna like an Antron 99 would be better than the discone you said you ordered. Most 10m amateur radio activity is horizontally polarized while most CB activity is vertically polarized.
Maybe we should take a step back. What exactly do you expect to use this radio for? What are you interested in hearing? The radio covers 25 to 2000 MHz, but no one antenna is going to be effective over that entire range.
01-17-2013, 5:20 AM
Yes.
Thanks for the reminder about step 5. I practiced with 4 of my favorite FM music stations but I sudden realized it doesn't do much good to try scanning channels like that.
