Go Back   The RadioReference.com Forums > Scanners and Receivers Forums > ICOM Receivers
ICOM Receivers A forum for the discussion of all ICOM scanning radios and receivers.
Old 12-20-2005, 02:49 PM
Thunderbolt's Avatar
Default ICOM IC-R71A Power Cord
I have been searching all over the shack for my owner's manual and I can't locate it. Maybe someone can answer this question for me:
Did the Icom R71A come with a DC power cord? If so, what is it's model number?
Thank you!
73's
Ron
"A bank is a place where they lend you an umbrella in fair weather and ask for it back when it begins to rain." Robert Frost.
Old 12-20-2005, 05:22 PM
SEMTTP's Avatar
Send a message via AIM to SEMTTP Send a message via MSN to SEMTTP
Ron,
According to the manual, no. It says to contact ICOM for DC info.....Here is the link to the manual!
http://www.usersmanualguide.com/icom/receivers/icr71a
Eric
Eric-KB8UYC
Dispatcher for FNNM(fnnm.net)
http://flickr.com/photos/erchambers
http://kb8uyc.wordpress.com
Old 12-20-2005, 09:39 PM
Originally Posted by SEMTTP
Ron,
Eric
Thank you!
Old 01-05-2006, 12:34 AM
w8mkh's Avatar
Send a message via MSN to w8mkh
i have a r71a and as far as i know it is a ac only reciever
I MONITOR THEREFORE I AM
W8MKH
Old 01-05-2006, 11:20 PM
That is what I found out, the R71a doesn't have provisions for a DC power cord, but can be wired internally to operate off 13 volts DC. Moreover, later versions like the R72 and current R75, do allow for DC operations with a separate power cord. Apparently, Kenwood foresaw this problem and incorporated DC capability with their receivers.
73's
Ron
Old 02-03-2006, 12:17 PM
ghorine's Avatar
That's weird, I have an R70, and bought a DC cord for it years ago. Since the R71 was an upgrade to the R70 (added the keypad, voice frequency announcement option and IR remote control, as I remember) I would have thought it would have the same 4 pin DC connection on the back.
73, Greg
73's
Ron
Greg Horine
N9PBD
________________________
BCD396T, PRO95, PRO30,
PRO34, VR-500, PRO2004,
BC895XLT, MX5500, IC-251A,
IC-R70, FT-470,
Hallicrafters S-120, HTX-202,
TR-2600A
Old 02-20-2006, 06:54 PM
The DC operation was an option. was a connector that installed on the back of the rcvr and plugged inside as i recall. Used to have an r-71 and wish I still did!
Old 02-25-2006, 05:58 PM
73, Greg
How sensitive is the R70? I know that people who own the R72, really wish they had a R-71A because its far more sensitive. Likewise, I often read the same about a R75 as well. However, the antenna you use on your radio has a lot to do with it.
73's
Ron
Old 02-25-2006, 07:13 PM
ghorine's Avatar
The book sensitivity is <0.15 microvolts for 10dB S+N/N for CW, SSB, RTTY and 0.5 microvolts (3 microvolts 100kHz - 1600kHz). My experience with the radio shows that it's a very good receiver that needs a decent antenna. It won't display that kind of sensitivity with just a hunk of wire thrown around the room. My best experience was with a 100+ foot long wire and a good earth ground. I also modified my R70 to enable the preamp below 1600kHz. Although it can overload with nearby strong AM stations, it really helps dig out the beacons below 500kHz.
73, Greg
73's
Ron
Greg Horine
N9PBD
IC-R70, FT-470,
TR-2600A
Old 02-25-2006, 07:15 PM
dmaharajh's Avatar
I use a normal computer system unit power cable on my IC-R71A with the 3 female connector.
works fine! It's AC only
