Go Back   The RadioReference.com Forums > Scanners, Receivers and Related Equipment Forums > ICOM Receivers
ICOM Receivers - A forum for the discussion of all ICOM scanning radios and receivers. Please use another appropriate forum for transceivers.
Old 08-27-2014, 3:29 PM
russellmaher's Avatar
Question R-75 repair in New England area
Hello folks:
I have an R-75 that has been used very little, but has an illness that needs some attention and I don't know where to turn. Maybe some members (in the New England region) can give me some hints.
The unit will not power up and wiggling the power connector on the back will no longer solve the problem. I took the covers off and did an internal inspection and what I found is the culprit is where the power connection plugs into the receiver. It is loose and I believe that some re-soldering of that connector is needed. If I was younger and had better vision and the ability to handle a soldering iron without shaking like a new groom, I would give it a try. The unit is way past the warranty period, so voiding that isn't an issue, and I'm thinking an experienced techie could do the job properly without too much effort.
If any members here could offer some helpful advice or may know someone that could tackle this job in the local area, I would appreciate the info.
Russell
SEMPER PARATUS
BCD436HP HP-1 BCD396T BCT-7 BC350C PRO-2052 ICOM R-75 BC175XL REGENCY R-1050 TDXone TD-Q8A YAESU FTM3200DR FT70DR
