timgoldsmith
- Joined
- May 23, 2016
- Messages
- 2
Hello,
I just purchased an r7100 from overseas. I attached a proper scanner antenna I had lying around and plugged in the AC power cord and turned it on and the lights never came on and a sort of raspy sound came out of the speakers. Only had it on for a couple of seconds.
The seller assured me it was working when they sent it.
I popped the cover and noticed the wire jumper connecting two holes on the J4 position in the Reg unit so I can see it is set up for 240V overseas power.
Two questions:
Do I just move the wire over to the corresponding holes on the J3 to get the proper US AC voltage operation? The manual isn't clear enough to me what they mean about jumpers and dummy jumpers. Maybe I need to put my glasses on so I am not sure what the manual refers to
Would having the voltage set incorrectly present the way that I described? No lights and weird sound? (Did I fry it?)
Thanks for any help. This will be the first of many challenges if I get this thing up and running.
Tim
Two questions:
Tim
