Go Back   The RadioReference.com Forums > Scanners, Receivers and Related Equipment Forums > ICOM Receivers
ICOM Receivers - A forum for the discussion of all ICOM scanning radios and receivers. Please use another appropriate forum for transceivers.
Old 01-22-2018, 2:54 AM
Default IC-R20, Will Iose settings with battery discharge?
I don't find an answer to this in the manual. If I use the unit only on the rechargeable battery pack and it wears down, will I lose settings such as programmed channels, programmed edge scanning, etc?
Also, I heard it runs about 8 hours on a charge. True? Thanks to all.
Old 01-24-2018, 2:42 AM
Air490's Avatar
No, and it depends on your usage
Old 01-24-2018, 5:10 AM
You won't lose the settings, the R-20 has a non-volatile memory. Even with the battery off the radio it holds the settings.
