Go Back   The RadioReference.com Forums > Scanners, Receivers and Related Equipment Forums > ICOM Receivers
ICOM Receivers - A forum for the discussion of all ICOM scanning radios and receivers. Please use another appropriate forum for transceivers.
Old 09-14-2018, 3:08 AM
bgav's Avatar
Default IC-R30 Firmware v1.10 9/14/2018
Available now:
https://www.icom.co.jp/world/support...-R30/1_10_usa/
Model name IC-R30
Download Type Firmware
Version Version 1.10 for USA version
Update 2018/09/14
Notes
This firmware is for the USA version that has a serial number beginning with "16".
Changes in this version
Remote control operation with RS-R30I.
Automatic backlighting is improved.
Some restrictions of program scan edge settings are eliminated.
Skip function is improved.
Duplex check function during the memory scan is added.
Duplex scan function is added.
Memory group and group link settings are connected.
Channel UP/DOWN is available across channel groups in the Memory mode.
Bluetooth® SCO Link can be automatically disconnected when there is no audio.
Volume of a Bluetooth® headset and the IC-R30 can be separately set.
Battery condition information is added.
The record file management system is improved.
Click here for more details
To update the firmware
Thoroughly read Section 2 microSD CARD and Section 9 UPDATING THE FIRMWARE in the ADVANCED MANUAL, and follow the instructions displayed on the IC-R30.
BE SURE to make a backup copy of your data settings before updating the firmware.
The firmware will be updated to the following versions.
CPU to Version 1.10
DSP to Version 1.03
HP-2 | BCD436HP | PSR-800 Whistler Upgraded | IC-R30
Old 09-14-2018, 3:14 AM
bgav's Avatar
Manual attached.
Link: http://www.icom.co.jp/world/support/...ENG_INFO_0.pdf
Old 09-14-2018, 6:39 AM
Hit_Factor's Avatar
When I updated my R30 it completely reset. So make sure you save CSVs of all your memory, scan edges, and GPS data.
73, K8HIT
Icom: IC-7300, ID-5100A, ID-51A Plus 2, IC-R30 Yaesu: FT2DR & FT70, Hytera PD782G, Uniden SDS100
DVMega running Pi-Star: D-Star, DMR, System Fusion, P25, NXDN, SDRplay RSPduo
Old 09-14-2018, 8:39 AM
tumegpc's Avatar
Just downloaded the firmware , Thanks Hit_Factor .
ICOM IC-R30 - 436HP -TRX-1
Old 09-14-2018, 9:05 AM
Updated.
Thanks for the heads up!
Old 09-14-2018, 9:20 AM
bgav's Avatar
Yup, same happened to me.
Old 09-14-2018, 9:47 AM
The CS-R30 software has also been updated
Old 09-14-2018, 12:41 PM
Hit_Factor's Avatar
Where did you get that? I have had it on backorder for months.
73, K8HIT
Old 09-14-2018, 12:54 PM
HRO had some in stock, but it looks like its gone. Really wish Icom would just let the dealers sell the keys and put it online for download.
Old 09-14-2018, 7:01 PM
Hit_Factor's Avatar
So do you like the software? Have used ARC30 or RT Systems for comparision?
73, K8HIT
Old 09-14-2018, 7:29 PM
Haven't used other software. CS-R30 is very simple and straight forward. However, you can't edit multiple channels at once. If you wanted to change multiple channels from AM to FM, you'd have to do it one by one. It's probably too simple for the price tag. The other software options look like a better value.
Old 09-14-2018, 10:26 PM
Thanks ICOM for removing the scan edge limitations. It was driving me crazy having to re-set the mode every time I searched the USA UHF aviation band. Also I really like the DUP frequency check function.
Old 09-15-2018, 3:38 AM
Air490's Avatar
It appears ARC30 is not currently working with firmware version 1.10. I tried to copy data from the scanner into ARC30 to have a play with it but it's not working. The software does appear to be receiving any data from the scanner.
Old 09-15-2018, 4:51 AM
Butelsoftware's Avatar
Do you have more exact details? I have not updated to 1.1 yet.
Gommert
Butel Software
>>> Visit us at the 2018 Dayton Hamvention! SDS100 will be on demo! <<<
Dutch Design: best selling scanner software in the USA
US Sales: 1-800-SCANNER http://www.scannermaster.com/?Click=41054
Old 09-15-2018, 5:17 AM
Ok it looks like the firmware update resets the USB settings. Just follow the instructions in green/blue in the Read/Write window in ARC30 and then it should work again.
Gommert
Butel Software
Old 09-16-2018, 10:24 AM
LEH's Avatar
LEH LEH is online now
Should I upgrade my R-30 to the 1.10 firmware? If so what issues do I need to fix once upgraded?
I've heard that USB connection needs to be restored (so I can use the Butel beta software) and that I will have to reload my files. Anything else? I haven't used the GPS so nothing saved there.
Lynn
Old 09-17-2018, 3:51 AM
Air490's Avatar
Gommert
Butel Software
It was operator error. It helps to export the data to the card before you try and export it to the software...
