To be more successful in the milair game, an external antenna is almost a must. Something along a discone or scantenna, mounted nice and high, with good coax (no I don't mean that junk RS sells...).
Most duckies are great for stuff nearby, but fall short when you try to do anything that's a good distance away
Now for additional freqs - I'd look at the UHF ARTCC freqs for Salt Lake City and Seattle (depending on where you are...). Unfortunately the info in our database is pretty dated, so a question in the Washington and Utah forums might be in order, but here are the links to our database...(always ignore the FAA listings- they're frequently out of date...)
http://www.radioreference.com/apps/db/?aid=2237
http://www.radioreference.com/apps/db/?aid=2235
The IdaScan and NWScan Yahoo groups might also be a source of info. They're linked here...
http://wiki.radioreference.com/index..._Mailing_Lists
73 Mike
links editor,
Utility Monitoring Central
