Not sure if the actual layout for ITTF regions has changed or not, but a little while back the naming protocol for ITTF region TGs in Starcom 21 radios was changed. These changes are reflected in the SC21 profile posted at the CARMA website
http://www.carmachicago.com/profiles/StarCom21.pdf - take a look at the 303xx-series TGs and you'll see that they differ from that original plan shown on the Moto map you referenced.
AFAIK, these regions now mirror the region layout plan for IEMA - a map of those regions can be found at
IEMA | Regional Contacts .
Hope that helps...
Originally Posted by chip448
Does anyone know where a map of Illinois Terrorism Task Force regions can be found? I have been unable to locate one on CARMA or RadioReference. I found a PDF map from Motorola that appears at first glance to be the correct ITTF map, but there are more regions on the map than there are SC21 ITTF region talkgroups.
