Go Back   The RadioReference.com Forums > U.S. Regional Radio Discussion Forums > Illinois Radio Discussion Forum
Illinois Radio Discussion Forum - Forum for discussing Radio Information in the State of Illinois.
Old 01-23-2012, 8:28 AM
Default Help with tow truck frequencies.....
Trying to find four local towing company frequencies. They do police tows for most of the agencies in the far south suburbs of Chicago(i.e. Chicago Heights, Steger, Crete,etc.). The four I' m looking for are TMW in Crete, A-1 and Expert in Chicago Heights, and Coy's in Matteson.
I have searched RR and CARMA, no luck.......
Old 01-23-2012, 9:16 AM
Scannerhead1983's Avatar
Location: Iron Triangle Ohio... otherweise known as Fostoria. Where the trains roll through every 5 minutes.
Sometimes a lot of tow companies lease radios/repeaters from local communications companies. In my area a lot of them used to run on UHF LTR systems owned by various communications companies. That may be a good start, Though they may not be listed in any database. Sometimes it's hit and miss, you just have to program the LTR frequencies in your scanner in Locical Channel Order, Similar to how you would program an Ericsson system. Once you have the repeaters in order, Scan in open mode and see if you can pick up anything that sounds like tow companies. Often times too they may just simply be using radios without a license... I've seen that done plenty of times through out the years as well. Good luck
Motorola XTS-2500I ASTRO25 800Mhz/Motorola CDM1550 UHF/Motorola HT1550-XL UHF/Motorola CDM1250VHF/Motorola M-216 UHF/Icom IC-280 2meter.
Old 01-23-2012, 10:48 AM
I agree with Scannerhead1983. Also, they may be using only cell phones or NEXTEL.
Old 01-30-2012, 8:43 PM
AC9BX's Avatar
What they said.
I hear a few towing companies near me on a region wide trunk system. It especially happens when companies consolidate. What was a local company is now regional.
It can be a challenge to track these down. Using a "spectrum sweep" feature if you have it available in proximity to one of the trucks or offices may help you find at least one frequency which you can then use to maybe identify the system.
Pro-2021, Pro-197, WS1095, DX398, BC348, Flex-1500, Quansheng TG-UV2, Yaesu FTM-350AR, Yaesu FT-897D, Realtek USB SDR, Baofeng GT3
Old 01-30-2012, 9:04 PM
trsundstrom's Avatar
Mentor
Just for jollies, perhaps the FCC db will turn up your tow companies. Try Site / Market / Frequency Query and see what happens. They might be in the IG service.
Tom - W2XQ - w2xq.com
Old 01-31-2012, 2:00 AM
stevelton's Avatar
I would also suggest that since these tow companies are in the chicagoland area, they may be using ABEEP's NXDN trunked system. NXDN trunking itself is hard to monitor, and I would bet a few pennies its encrypted.
Steven
Old 01-31-2012, 2:39 PM
ABEEP LKPT Ltr=TG 0-08-100=Heartbreak Towing....ESP Wireless #1-900mgz-TG3869=Ohare Towing....Just a couple i monitor in bad weather....
RoninJoliet
Old 02-01-2012, 11:57 AM
What's the frequency, Ron? !
Old 02-01-2012, 2:29 PM
The ABEEP LKPT LTR System uses about 10 freqys but the "home" rptr is 464.30....The ESP 900mgz is five freqys and the CC lands them on anyone.....
RoninJoliet
Old 02-01-2012, 10:26 PM
Thank you much! That's a start. I know that A-1 towing went trunked back in the 90's (I knew one of the guys that towed for them, he told me about it.). But dont know where they are now. I could just start plugging the systems in to the scanner and see what comes up, but that could take a loooooooooooooong time before I get the ones I'm looking for.
Old 02-02-2012, 2:52 PM
Go to the "database" on this web site, go to "Cook Co" and scroll all the way down to the "trunk systems", for LTR UHF and 900mgz, check them out as i did seeing if i could hear the system using my outdoor antennas, then check the users and thats how i found "Ohare Towing' on 900mgz....They have a "rptr" in Joliet....
RoninJoliet
Old 02-02-2012, 7:20 PM
W9NES's Avatar
You might to a scan from 150-151.999 for Auto Emergency Frequencies. You might check freqs like 150.815 150.845 150.860 150.875 . Also you could check 461.0-464.999 and see if you hear them in UHF.on a Repeater. One local Towing Service here in Metro Indianapolis uses 461.550 on a repeater with a PL Tone.
Tags
frequency, tow trucks
