Originally Posted by pm91
Hi,
I know I'll have to know enough pass the test and the rest of the family won't use unless it's an emergency and we won't really care if they are licensed or not if that happens.
You don't want unlicensed people using your amateur equipment even in an emergency unless you are the control operator. Allowing someone to use your equipment will bring the enforcement people knocking at your door. You could lose your license and be fined. But you will learn all about this as you study for your ticket.
Initially, all I'm looking for is a good place for equipment recommendations based on my needs and then whichever book I'll need to understand all of this (easy and simple - please) and pass the test.
As far as equipment is concerned you will have to decide if you want handheld radios or mobile radios or a combination of the two. Handheld radio's typically are low power and you may or may not hit a repeater with them. Mobile radios put out much more power and then you need to get an antenna(s) for the radio(s). Again you will learn about this as you go through the process.
There are a ton of sites that help with passing the test by learning the answers to the test questions which is great, but I need some sort of foundation first.
If someone could point me in the right direction or a top 10 ham forum to join that would be great!
Paul I suggest you talk with someone in your local club. If you go to
American Radio Relay League | ARRL - The national association for AMATEUR RADIO you can find a local area club. Most clubs put on classes to teach the material that you need to learn. Best of luck in getting your ticket.
