Originally Posted by speedway_navigator
I installed PSRedit and was able to read the radio, then made a few changes to fix some tag names that I had duplicated. When I tried to load the scanner with the program the scanner got to 92% and died. PSRedit said it was 100% done.
This is usually caused by an older version of the Firmware on the PSR-600. You can check the Firmware versions by pressing the #3 key while the welcome message is on the screen when you turn the scanner on.
There are two ways to resolve this if you have an older firmware version.
Option 1: Download the latest firmware from the GRE America site at
GRE America, Inc. - Powered By Kayako SupportSuite and update the scanner. The latest versions of firmware are CPU 1.6, and DSP 1.3. I would suggest updating both to the latest. This may help your reception as well.
Option 2: On the serial port configuration screen, check the option to add extra time while uploading. This will resolve the problem with uploading.
