Go Back   The RadioReference.com Forums > Regional Radio Discussion Forums > Indiana Radio Discussion Forum
Indiana Radio Discussion Forum Forum for discussing Radio Information in the State of Indiana.
Old 08-26-2009, 05:23 PM
Default External Antenna- 50 ohm or 75 ohm coax?
I have literally 1000' of RG59 and RG6 coax which is 75 ohms. How important is it to use RG58 (50 ohm) coax for my external scanner antenna. Would I see any signal loss if I were to use RG59?
Old 08-26-2009, 06:30 PM
n5ims's Avatar
You'd actually see a signal gain using RG-6 over RG-58 for recieve use. RG-58 is really lossy at high frequencies since it was designed for use on much lower frequencies than used on most scanners. RG-6 was designed for VHF and UHF TV and is much lower loss at those frequencies than RG-58.
Unless you transmit (or have a very specialized setup) you will never see the loss from the impedence difference between 50 ohm and 75 ohm cable when using a scanner.
Old 08-26-2009, 09:54 PM
gewecke's Avatar
Wink
True. Also RG6 quad shield works very well for scanner use too,which I have on one of my antennas
N9ZAS
Old 10-04-2009, 05:15 PM
Default RG6 for CB Usage
I know that I can use this coax for CB usage as well however, there is electrical length calculations to be figured. Anyone have the formula for calculations on different wavelengths in figuring the electrical length? Thanks.
Similar Threads
External antenna sugestions wb3j Antennas and Coax Forum 6 10-13-2008 08:45 PM
50 ohm to 75 ohm grey4trains Antennas and Coax Forum 1 07-23-2008 06:17 PM
800Mhz Yagi Antenna with coax (question) W9NES Indiana Radio Discussion Forum 16 07-16-2008 08:19 AM
NWS Overload afer putting up external antenna jhodal Uniden Scanners 2 12-20-2004 11:05 PM
House Mount External Antenna Question coyote1964 Antennas and Coax Forum 2 09-15-2004 02:57 PM
