Everyone should be making the switch to using plain language and doing away with 10 codes and signal codes anyway. One of the main reasons for the switch to SAFE-T is interoperability. This goes for the state level and even the national level. Although Indiana uses the same codes (for the most part) statewide, there is no-interoperability nationwide. This was brought to light after September 11, 2001 and Hurricane Katrina. You had multiple agencies from various jurisdictions trying to communicate. Using code talk only complicated communication when codes mean different things to different agencies. This is why every SAFE-T radio must have the ability to transmit on various regional Mutual Aid Channels, but also on the NPSPAC channels. One of the rules when we were assigned our SAFE-T radios, is that we use plain English. There are certain situations where we still use codes. If there is an officer safety issue, the dispatcher might say Signal 48? rather than "is the subject with you"? Most of the time that tells us that the subject is wanted. Some people, hearing that they are wanted over our radios, might use that opportunity to try to run or hurt us.
