Go Back   The RadioReference.com Forums > U.S. Regional Radio Discussion Forums > Indiana Radio Discussion Forum
Indiana Radio Discussion Forum - Forum for discussing Radio Information in the State of Indiana.
  #221 (permalink)
Old 07-24-2014, 11:15 PM
usswood's Avatar
I think he wants someone who can hear the tower to report the cc Mark ... RR data might be outdated
usswood
  #222 (permalink)
Old 07-25-2014, 10:43 PM
W9NES's Avatar
Mark Anderson is asking about the Greenwood Safe-t tower site. The Control channel is 853.375 and the alternate is 852.900
  #223 (permalink)
Old 07-25-2014, 11:08 PM
No, he is not. He was answering me and Usswood is correct, I am looking for someone to physically verify the tower CC. I know what the DB says, but think it is incorrect.
  #224 (permalink)
Old 07-27-2014, 7:32 PM
jtsmith82391's Avatar
I just checked it and I'm hearing the cc noise on what's listed as the alt cc.
Sent from my SPH-D710 using Tapatalk
  #225 (permalink)
Old 07-27-2014, 7:42 PM
Thank you so much! Exactly what I was looking for.
  #226 (permalink)
Old 07-27-2014, 7:43 PM
You're very welcome.
  #227 (permalink)
Old 07-29-2014, 7:05 AM
JStemann's Avatar
Default p25 equipment
Heard last week, equipment being delivered to sites in SE Indiana. I'm going to assume it's the p25 equipment. Techs mentioned several sites around SE In.
Jeff.
ab9uw
BC-396xt, RS Pro-96, BC-785D, BC-996t, IC-92AD, Ft-7800, Ft-897D, Kenwood Tm-D710a, Tm-V71A, BC-996xt, Hp-1
  #228 (permalink)
Old 08-02-2014, 3:41 PM
usswood's Avatar
Default Very Strange Tower 038 - Terre Haute
This site is now showing two (2) alternate control channels
852.0750 and 852.8000
usswood
  #229 (permalink)
Old 08-02-2014, 6:44 PM
KD4YGG's Avatar
Many of the sites in the southeast part of the state have multiple alternate CC's
  #230 (permalink)
Old 10-09-2014, 10:40 AM
Linneweh's Avatar
Question Control Chanels?
I hope this is the correct thread, so here goes. I travel to Indy several times a year, and have SAFE-T programmed, but hear very little of the State PD. I noticed that the control channels listed in the data base do not match what is shown on the IPSC inter active map. []IPSC: Home. All the controls are 861 to 865 MHz, the RR DB has them in the 853 to 859 area. Which is correct? I can't find dates on either chart, so I don't know the latest one.
  #231 (permalink)
Old 10-09-2014, 5:35 PM
milf's Avatar
Careful, I CAN hear you!
The RRDB is correct and up to date. SAFE-T has been rebanded, and is beginning upgrade to P25 Phase 1. First of the new sites is the Master Control in Indianapolis. Site 149. Testing at this stage. Other sites should be appearing very soon down south.
PRO-92, PRO-92B, PRO-96, BCD396XT, BCD436HP+DMR
APX6000XE
  #232 (permalink)
Old 10-09-2014, 7:27 PM
Some info on the new Safe T system change over if it has not all ready been posted
Work has already started on the Indianapolis Controller #1 and is up and running in test mode. The new P25 will be 9600 P25 Phase 1 with a upgrade to Phase 2 way later if so chosen to do so the new system will support that.
Both the old System and the new will be online at the same time and cut over will happen a little at a time. Witch means you will want both systems in your scanners since some users will be on the New and some on the old for a period of time. This means that the new radios will have dual programming templates in them.
Each region may take weeks to cut over. Current XTL/XTS radios will work on the new system. MTS 2000 MCS 2000 MTX LTX and Spectra will NOT work on the new system hence a lot of agencies are trying to find funds to upgrade there radios. New talk groups in some areas will be set up so be looking for that.
This will be a 2 zone system and no longer 4. All rebanding was done a long time ago so for the person asking on CC they all should be in the 850 to 859 range and the RR DB is up to date other than the NEW P25 9600 site online now at a CC of 855.9625 in Indianapolis.
You will also see a lot of CC changes on the old system as new systems come online and testing is being done.
Sorry if some of this has been posted before just want to pass it on if it has not
  #233 (permalink)
Old 10-09-2014, 8:03 PM
milf's Avatar
Almost every site of the existing SAFE-T Legacy system is adding new freqs to prepare for traffic growth on the system after the upgrades. there are also a lot of new sites that will be built over the next 3 years, as well as existing county/municipal systems converting over to the SAFE-T P25. Full transition is expected to take an additional 2 or so years after the full upgrade is completed in 2015/16. Expected final termination of the original SAFE-T system by 2018 at the latest. (Optimists say late 2016).
APX6000XE
  #234 (permalink)
Old 10-12-2014, 5:45 AM
I am unable to pick up safe-t traffic in Wabash county on my pro-2096, I have the controls freq of 852.97500 and alternate of 852.48700, I have also updated my table for 800 re branding. It has been a few months since Ive turned on my scanner and it worked great. Any suggestions?
TIA
  #235 (permalink)
Old 10-21-2014, 6:07 AM
kc9cau's Avatar
Default ID on unitrunker
he all i have no idea if this is a radio or a unlisted TG but i am seeing number 41994 constantly logging in and logging out on the unitrunker program while monitoring the valpo site there it has yet to have a call come up just keeps saying login and logout any ideas as to what this is
  #236 (permalink)
Old 10-21-2014, 3:55 PM
usswood's Avatar
It's a radio ID sir! Most likely on the edge of that tower and keeps affiliating / deaffiliating with that tower
Here are two other ID's in that range:
41993 ISP 22 ISP State
41995 Motorola Motorola State
usswood
  #237 (permalink)
Old 10-21-2014, 10:55 PM
kc9cau's Avatar
ok thanks that is what i thought but i figured i would confirm with more people in the know
  #238 (permalink)
Old 12-14-2014, 4:46 PM
Default Which scanner?
I'm looking to purchase a scanner to monitor a few channels in SAFE-T. Specifically I am interested in Clark County Fireground 4, which I believe is represented by this entry:
31504 7b1 D 10 FIRE 4 Utica and Borden Fireground Fire-Tac
I'm (completely) new to scanning, so was wondering if someone could point me in the direction of a scanner that would pick this up.
Thanks!
  #239 (permalink)
Old 12-14-2014, 7:14 PM
milf's Avatar
Any of the digital capable scanners will work on the current system. Anything from the Radio Shack PRO-96/2096's and Uniden BC 250D up thru the Whistler WS1080, and Uniden BCD436/536HP's, and HP1/2.... But after this next year, if your thinking Uniden, you will want more along the lines of the BC396T/996T or XT versions up thru the new HP-2. The SAFE-T is upgrading to full P25 Phase 1 digital.
APX6000XE
  #240 (permalink)
Old 12-14-2014, 8:44 PM
markanderson's Avatar
what about Pro 106 radio shack
Tags
ipsc, safe-t
