A few people from the All Ohio Scanner Club have reported good results using this antenna on Phase I simulcast systems in Cincinnati/Hamilton County and Butler County, Ohio so I picked up a couple of them at an electronics store in the Cincinnati area on the way to Hamvention. They are also available through Staples (and I'm sure other locations). Cost is about $10, plus the cost of a F-type to BNC adapter.
So far I'm getting very good results listening to SAFE-T with it - very clear and very directional, just what you need for LSM/CPQSK systems. The mast rotates and elevates. Size is similar to a small bankers desk lamp (sits great on top of any base scanner!!!). I'm getting SAFE-T sites at 99% signal strength that are over 30 miles away from my QTH.
Supports HDTV 1080p, 1080i, 720p Broadcast.
Full Band DTV/UHF Receiver UHF to 860Mhz.
High Front to Back Ratio Helps Reject Unwanted Multi-Path Signal Corruption.
Flat Forward Gain Slope Delivers Balanced Reception.
Wall Mountable Design
3 foot pigtail coax cable.
Supersonic® SC-602 HDTV and Digital TV Indoor Antenna | Staples®
Supersonic HDTV and Digital TV Indoor Antenna 927517 - Micro Center
Thought this might help the ones in Marion County, in the southeast near Cincinnati, and across the river from Louisville.
