Go Back   The RadioReference.com Forums > U.S. Regional Radio Discussion Forums > Indiana Radio Discussion Forum
Indiana Radio Discussion Forum - Forum for discussing Radio Information in the State of Indiana.
  #21 (permalink)
Old 12-24-2017, 2:03 PM
eaf1956's Avatar
Originally Posted by trido View Post
New Harris P-25 phase 1 system.
I will say so far no users on the P-25 side, what they are doing is all users still on Edacs but system has a Harris gateway to P-25.
Simple terms EDACS in and P-25 out the 3 site simulcast system.
A couple of us have been testing scanners the last two weeks.
At first most any digital scanner was doing OK.
However we both feel something has changed on this new Harris P-25 phase 1 system.
All our Uniden models plus Whistler TRX-1 are missing traffic at times.
Sometimes the start of a dispatch other complete mixes dipatcher and mobiles.
Dreaded Simulcast issue and it being HARRIS.
Only radio that works and works well Unication G4 and G5.
Well no real surprise but had hoped only being a 3 site system we might not have this issue.
Sadly we do.
So are ALL the TG's from EDACS being translated to P25? I only seem to get EPD Dispatch and VCSO Dispatch. None of the Info, Car to CAR, or MP East, West, etc..
Current scanners:BCD 996XT,BCD996P2
BCD536HP (2)
Ham Gear: Icom 7000, U82, V82, V8, IC 2820, MD2017, Vertex Standard EVX 539, MD 9600, CS 800D, and a YAESU FTM400DR
  #22 (permalink)
Old 12-24-2017, 4:14 PM
trido's Avatar
yes to tg.
somewhat confusing and I may not be the best to describe affiliation.
Just like the States Safet system for US to hear a TG we must have a radio affiliated with a tower on the system.
right now no users are using the new P-25 system.What is happening we have some people that tuned their radios to the P-25 system and they park their radio on ONE TG at a time.
So for now hit or miss we hear any trafiic on P25.
Hope I have that all right and not confused it all.
They have in place a HARRIS gateway bridge i call it.
Meaning edacs in and P-25 out but again for us now all are Edacs in and we must have someone on the P-25 system parked on a TG to hear that TG via P-25.
Two way gateway P-25 will go in and out Edacs. This is so they can migrate users over to P-25 .
  #23 (permalink)
Old 12-24-2017, 6:28 PM
eaf1956's Avatar
Pro96 is showing:
401
201
611
502
202
205
201
514
501
502
so far here on affiliation log.
So from your info I can assume that I or We won't hear any traffic on the P25 side if there is no radio affiliated with whatever TG is being used on EDACS. Also, they seem to only be using 2 Voice channels currently.
BCD536HP (2)
  #24 (permalink)
Old 12-26-2017, 7:30 AM
lviper's Avatar
No, the TG ID's are not translated over to the new system, only the transmissions. The TG ID numbers will be different on the new system.
Scanners - Uniden BC396T, BCD996T and Pro-2022 Modified
  #25 (permalink)
Old 12-26-2017, 8:08 AM
trido's Avatar
right p25 tg are dif numbers than edacs. I meant to say or tried to say you will see the NEW p25 TG numbers if you monitor the p25 system.With a scanner or pro96 software.
that gateway takes edacs TG and sends out P25 TG out P25 system
QUOTE=lviper;2858377]No, the TG ID's are not translated over to the new system, only the transmissions. The TG ID numbers will be different on the new system.[/QUOTE]
  #26 (permalink)
Old 12-26-2017, 10:20 AM
milf's Avatar
Careful, I CAN hear you!
Its the same as Moto Smart X bridge system. You are using the EDACS side (The freqs still allocated anyway) and your transmissions are simulcast on the P25 side for those already transitioned and for testing... Reverse is also true. You use the P25 side, and its simulcast back on the EDACS for those still using it. This allows for a longer transition and more testing as you switch out the systems. Useful if you have NOT fully prepared to transition and do NOT have all your gear ready like you should... Wink wink
Though usually this is more common when going from EDACS to Motorola since its completely different gear at the core level, or going from LTR to P25... Or have an set of analog systems that are future transitions to an much larger P25 system.
APX6000XE
  #27 (permalink)
Old 12-26-2017, 12:28 PM
eaf1956's Avatar
I wasn't referring to the numbers. EPD DISP on p25 seems to be 201
BCD536HP (2)
  #28 (permalink)
Old 03-01-2018, 12:26 AM
Any updates?
  #29 (permalink)
Old 03-01-2018, 5:30 AM
trido's Avatar
The only agency I think is on P-25 full time is Airport Maintenance.
Reason don't think they ever were on EDACS and now they are on P-25. TG 659 D ERA-MAINT Evansville Regional Airport Maintenance Public Works
this and I may be wrong is the ONLY user on Full time P-25(meaning no Edacs Gateway from P-25 to Edacs)as this user was never on Edacs before.
Pd seems to be on Gateway many times(meaning someone has a radio parked on PD DISP P-25 system).
Dispatcher on PD sound terrible thru Gateway no idea why, sure that clear up once they are on P-25.
Well March 5th the system will have been turned on 3 months.
Not sure how much longer it takes to get system all setup.
Originally Posted by cryppie View Post
Any updates?
Jeff
  #30 (permalink)
Old 03-02-2018, 11:41 PM
Reason don't think they ever were on EDACS and now they are on P-25. TG 659DERA-MAINTEvansville Regional Airport Maintenance Public Works
Thank you very much for the update. I'm not looking forward to losing metadata on my feed so hoping they take a very long time to get off legacy edacs completely!
  #31 (permalink)
Old 04-09-2018, 5:39 AM
trido's Avatar
Default News Story
Evansville upgrade from EDACS to P-25.
I would say accurate story on upgrade.I hear about 90 days to completion.
NEWS STORY
Jeff
  #32 (permalink)
Old 04-17-2018, 9:28 PM
Hey Jeff, Congrats on the retirement. I stopped in N Fulton Ave the other day and found out.
I stopped in last fall for a scanner upgrade and you mentioned the Evv new system was in the works. Which scanner would you recommend for the new system?
Thanks.
Doug
  #33 (permalink)
Old 04-18-2018, 4:32 PM
eaf1956's Avatar
Post
Thanks.
Doug
The SDS 100
BCD536HP (2)
  #34 (permalink)
Old 04-18-2018, 5:56 PM
trido's Avatar
Like EAF posted I would strongly say wait for the uniden SDS100.
https://www.scannermaster.com/Uniden.../10-501979.htm
Jeff
Thanks.
Doug
Jeff
  #35 (permalink)
Old 04-19-2018, 10:36 PM
VASCAR2's Avatar
Default Vanderburgh County P25 TRS
I got near enough to Vanderburgh County tonight to test my Uniden BCD996XT scanner on the new Harris P25 system. The Vanderburgh County EDACS system was busy but I didnít catch any traffic on the P25 system.
I did get the control channel on 856.5125 and system ID: 000Ah-1010. I didnít get any patched traffic from EDACS to P25. I get better coverage in Southeast Illinois on the EDACS system than the new P25 control channel. I couldnít tell if the simulcast system was having any affect on the range of the P25 system. Once they go live I should get a better idea on how much trouble the simulcast system creates.
